Air Filters
I have a 1998 K1500 Suburban 5.7, 3:23,4L60E w/B&M RV Shiftkit,Corvette Servo,Flowmaster Delta Force Cat Back SUV 50 Series,new fuel filter,tornado fuel saver,amsoil. I am getting exhaust out, everyone is telling me change my intake filter or intake kit.............Is it worth it? :cheers: I am dead against K&N, :chevy: tryed that before w/other cars and found dirt headed toward engine past the filter, if I do it want to stay w/foam filter type :cheers: ,is it worth it ?
unless your engine is really modified, the stock paper filter will flow way more air than that engine can consume. I tried an Amsoil foam filter before, they are in the same league as K&N. The Amsoil filter did two things for me, the first was to let dirt through, and the second was to make my wallet contain $50 less. :crackup:
The AMSOIL foam air filter will flow more air, but is a trade off on letting more dirt through as well. I have talked to several that used the AMSOIL foam filter and some had good results and others had bad as in letting more dirt by. Each application varies.
I have the AMSOIL filter on mine and the oil analysis show the same amount of silicon (dirt) in the sample as when I ran a stock AC paper filter. Now the AMSOIL foam filter on my wifes Venture shows a slightly elevated level of silicon in her oil analysis. Nothing major in my mind but it was a little higher. You also need to make sure the entire intake system is air tight along with any possible opening to the engine like your PCV valve and any other line that pulls a vacuum.
I haven't seen any test results done so far that proved an engines distruction due to running a K&N or Foam cleanable filter or any of the other cleanable filter out on the market today. At what point will letting in a little extra dirt start to kill an engine to the point of complete failure, 20K, 100k, 200K? Yep, dirt is not a good thing, can't disagree with that. It is a trade off, air flow for efficiency. It all depends on what an individual wants. Most don't keep their vehicles long enough to make a difference, which also doen't make sense if they get the cleanable air filter to save money from purchasing paper filters.
Like I said, they do let more dirt in, my venture is proof. Just depends on what you want.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
