And now I have a hole in my roof
Stepside Z
Well, I'm having a big oak tree removed from the back yard, and the tree trimmer came up to me when I got home from work and said "In ten years I've never damaged anyones property..."
Needless to say I now have a 4" hole in the roof of my garage!!!  He'll take care of it of course, but the darn garage is only 4 years old!!!  Bummer...
Sorry to hear about the bad luck Shane.
I get that stuff alot also...
"In 5 years of driving I never had a wreck, Until YOU came along! (Talking to me of course...)" etc.
Sorry, just trying to lighten things up......
Look on the bright side, your truck could've been parked in the garage and it could've fallen on it.  Besides that's nothing, my truck was 4 months old when it got smashed up, how do you think I felt???
Sorry to hear about that Shaners. It's a good thing that the guy is fixing it for you. I just fixed a roof this morning that had a tree fall on it. No hole in the roof, but a broken board and a few bad shingles. The bill was over $600. Make sure it is fixed right, so you don't have any future problems.
What happened was the limb hit right at the seem between two pieces of OSB, and dead smack in between 2 rafters.  That has to bee the weakest place you could drop a branch on.  He was going to screw a patch on from the inside to push the old OSB back up and replace 2 or 3 shingles...
Check it out...
getImage.pl?imgID=6050636-58b2&trans=
HMMM osb (sob board i call it) seems to not be as strong as plywood.
Used to work with that stuff everyday in the lumber yard.  Plywood always held up so much better.  Also when that stuff gets wet it sure does get soggy
Quote from RyanbabZ71, posted on Sep. 17 2001,20:18
I agree that Plywood is stronger, but the problem with it on roofs is that it doesn't have enough nailing area to make it not bow. On the roof, trusses are set at 24" instead of 16, so the plywood tends to bow alot. Another thing is that plywood doesn't hold the smaller fasteners very well that are used for the shingles.
Shaners, the pic doesn't show up, so I can't see exactly what you are talking about. Does the guy plan to use a 2x4 to screw in between the rafters to support it? If that is what it is, it should work fine as long as there is enough of the OSB left to nail the shingles to. Just make sure when you reroof the house that the OSB is replaced if it is really bad. Probably not a problem, but take a look at the rafters to make sure the didn't snap or splinter at all from the jolt of impact. Any more questions, I'm glad to help out.:DOne more thing, if the hole isn't too big, you can cover it with a piece of flat metal flashing to give it a little support. We have done houses with boards that knots are falling out of the boards and the inspectors are OK with us covering them with metal if they are not too big.
"plywood tends to bow alot"
yep osb never bows
at work i have seen some sheets of plywood bow so bad they almost looked like tubes.  Only way to straighten them out was to park the forlifts on top of them overnight and that still didnt help in most cases
Quote from RyanbabZ71, posted on Sep. 18 2001,08:55
yep osb never bows
OSB only bows when it is under stress or gets wet. When it is fastened it doesn't bow. Plywood bows quite a bit easier. I've seen where plywood pulled the nails right out of the rafters because it was bowing so bad.  Also, OSB holds the shigle fasteners much better. Another reason that OSB is used on the roof is that when the shingle nails go through it, it doesn't splinter on the inside like plywood does. The main reason that plywood is used now days is for flooring, and that is mainly for when a hard wood floor is going to be applied. And the reason for that is because plywood can be sanded much easier than OSB.
Shaners, the same guy that did the damage was going to do the repair?
He should be insured, make him file a claim and have a professional roofer do the repair!  You shouldnt have to put up with a shoddy patch job when it was his fault....
just my .02
Quote from patrick, posted on Sep. 18 2001,11:16
just my .02
Not a bad idea, but the problem (like with all insurance) is the deductible.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
