Floor mats
Hello,
Has anyone run into any good floor mats for our Silverado's that will keep the salt and water off our carpets. It seems that the rubber mats out dont seem to be wide enough and salt and snow runs off the gas peddle and onto the carpet as well along the side of the kick panel. At this rate my carpets will be rotted by spring.
Any ideas pls throw them my way.
Many different brands many different opinions...in my truck i have the X treme which i like alot and in my wifes S-10 blazer i have the husky and both do fine for winter weather
Yeah if I had to decide between my Xtreme's in my truck and the Husky's in my wife's S-10 blazer I would have to say the Husky's...they go up higher on the sides and seem to hold the melted snow alot better...but like i said before many different brands many different opinions
Go to www.stylinconcepts.com
Order Black Armor floor mats...they have 100year warranty, and are custom made for your truck...
I bought some for both my Tahoe and Equinox and there are non better...they fit exact, clean easily and are perfect
Thanks all for the great opinions and ideas. I ordered a set of Husky Liners today....$90.00CDN for the front pair. Should be in next week due to Christmas holidays. There is nothing worse than seeing dark charcoal carpets in a new truck look white from salt and now the carpet is soaked cause the mats I have now are not wide enough. Bring on the Husky's.
Later all.
Later all.
too bad you spent an extra $50 bucks...black armors are $59 ! O well enjoy
    • I imagine the cold winters up here with repeated short runs in town every day for those that live and work in town and given what I have come to learn on this forum with DI engines having fuel dilution issues, and if they don't change the oil until it says to but keep driving it for a while, I bet all that is just lovely on those finicky lifters.
    • I just did some reading and Stabilitrak is more than a what I had originally thought. It is more of a vehicle control system to help the driver in precarious situations. I thought it was only the AWD system. Now I know. So I changed the title for this thread to AWD conversion to Z71
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
