installed hi-five, now which wire?
i installed the hi-five on my truck and i was wanting to tap the power wire into the power for the parking lights so i can turn them on with the factory dash switch for the parkinglights/headlights. anyone know which wire that would be on the dash control cluster for headlight/dimmer/dome override?
TXD,
The factory harness plugs into the terminal block on the passenger side end of the dash. Open the passenger door and pull off the triangular panel on the end of the dash, then use a voltmeter or test light to find the correct 12V positive terminal switched with the park lights. I can't tell you the exact terminal right now, but is is near the bottom, I have done it a couple of times and it is easy to find with a meter. The factory harness runs down the RH windshield pillar to the terminal, so that is the best way to route your wires.
