Is it possible to buy painted bed?
Well, long story short, I got A dent on my passenger bed side. I want to replace whole bed, is it possible to buy painted bed from GM, my truck is two tone white and pewter on the bottom.
I really don't want the body shop to touch the truck, but if I have to, who knows a good body shop in Charlotte, NC
Thank you everyone; oh yes here is the pics.
The dent on the top part of the bed looks like it could be pulled out pretty easily, without having any real body work done. I'm not sure about the bottom two. I'd look into paintless dent removal, it would be considerably cheaper than buying a new bed.
Thanks SoCal:
I went to the local PDR shop and they said that they can't do anything and reffered me to the body shop. I was also surprized by their decision!
Look for a Paintless Dent Removal they can take it out. Dents ur use, Dents be gone are some of the names. Check you phone book. I have seen dents bigger than that fixed. GM only sell whole box in black and sides too.
Thanks redvett:
Well, this is not what I wanted to hear, but I guess I can't do Anything about it.
Here is Charlotte We have "Dent Magic", that where I went. Guy told me that he is limited to his own strength, and that this dent can't be pulled because it is warped to much. I don't know if he was BS'ing me.
Maybe I will try to go to a different place, and see what the other guys will tell me.
Thanks redvett:
I have seen Dents or us take dents like yours out without a problem. Maybe the guy yous talked to didnt like to use 3lb hammers. <VBG> When i worked at GM (retired) we hired they to remove dents out of our service vehicles and they took care of them everytime. I would check around a little more.
GM does not sell pre painted body panels. They come e-coated and you must have them primed and painted on top of the e-coat.
By the way they could never pre paint parts and stock them hoping they decided to paint the right amount of each color panel. Just not possible to do.
In the assembly process, Paint is the most costly process due to the energy it takes to heat and humidify a paint booth.
Lastly paint color changes from day to day based on mix and process parameters of the application equipment. You could never color match a pre painted panel.
Don't be afraid of body work and paint. Done by a quality shop you will likely never notice the repair.
Your best bet is to have the right bed panel replaced with a new piece. Any decent body shop can do a good job. White paint is pretty easy to match. If they attempt to take this dent out, there will be some body filler needed because the metal has been stretched so it will not pop out without creasing. Any way, this is a purely cosmetic repair. Your truck is 6 years old. Not worth losing your sleep over.
At first look, the dent could be pulled.
As for buying painted beds...check with truck outfitters, especially the ones that sell Stahl and similar commercial utility bed/boxes. They'll have bed takeoffs. Depending where you live, there are several places in the the mid-west that have acres of takeoff beds.
This may be true but I doubt the paint will match. Color is effected by gun pressure and color lots of paint when they fill the paint pots at the plant and there are about 5 plants that build the GMT 800 and color will greatly vary from plant to plant. May be close but you are better off getting a paint shop to blend for color match.
Nah, just buy one that's close, and never wash it.
:banghead:
:cheers:
Leave it to Wingnut to say something like that :banghead::troll::lurk:
You could put that dented, two-tone bed on my truck right now, and not be able to tell the difference.
Me truck be grubby. :banghead:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
