99' Tahoe (2 dr) front/rear axle fluid change
paulphilly
Got back from the dealer today after paying $600 for front/rear axle fluid change, oil change, transfer case fluid change, tranny fluid change, radiator flush/fill, new brakes/rotors turned. My question is how do I know they did all of these fluid changes? I crawled under my Tahoe today to check and there is only one plug on the rear axle which is at the top. So, I am assuming the only way to change the rear axle fluid is to remove the pumpkin and drain the fluid and then use a new gasket when putting the pumpkin back on? Then, use the top nut to refill? If so, my bolts on my pumpkin dont even look like they have been touched. Could the mechanic sucked the fluid out with some type of machine? I cant tell if he changed the fluid in either axle along with the transfer case. Please help!!
Yes, the fluid can be sucked out. Check your trans fluid on the dipstick, if it looks new they did flush it. You have a better chance of the work actually being done at a dealer than an indy.
Yes, the tranny fluid looks new. Ok, now I checked again with a flashlight and the rear axle had to be sucked out. The bolts dont even look like they were touched. So, if they did suck it out, how would I ever know the work was done?? And, should I have someone actually remove the rear cover and completely flush and replace with new gasket? He told me that he added the rear limited slip additive after I asked him if he forgot to put it in. But, that doesnt mean he really did it. Also, what about the transfer case and front diff? I got screwed like this before from another dealer and am very untrusting especially after spending $600. Thought?? Thanks
I kinda' hope they didn't put the additive in :mad: Its not needed or recomended by GM for use in the trucks
If there is no additive needed, can I use a fully synthetic on my 99' 2 Dr 4X4? The owners manual states to use a 80w-90 gear oil. Would the mobil 1 75w-90 do?
Yes,You can.This bulletin might help,Notice it says "do not add additive" and almost at the bottom of the bulletin it mentions putting in sythetic fluid in the front-end drive axle.
INFO ON RECOMMENDED AXLE LUBRICANT #76-02-02A - (Sep 29, 1998)
REVISION: 09/25/98 DIVS INVL 1 2 3 4 5 6 7
THIS BULLETIN IS BEING REVISED TO ADD THE 1998 AND 1999 MODEL YEARS AND ADD VEHICLE LINE AND RECOMMENDED AXLE LUBRICANT INFORMATION. PLEASE DISCARD CORPORATE BULLETIN NUMBER 76-02-02 (SECTION 0 - GENERAL INFORMATION). ______________________________________________________________________
SUBJECT: INFORMATION ON RECOMMENDED AXLE LUBRICANT
MODELS: 1999 AND PRIOR REAR WHEEL DRIVE PASSENGER CARS, LIGHT AND MEDIUM DUTY TRUCKS, AND FOUR WHEEL DRIVE VEHICLES
THE FOLLOWING TABLES PROVIDE THE LATEST INFORMATION ON RECOMMENDED AXLE LUBRICANT.
REAR AXLES WITH NON LIMITED-SLIP OR NON LOCKING DIFFERENTIALS
HD-3500 TRUCKS (DANA 11.0" GM P/N 12346140, SAE 75W-140 AXLES) SYNTHETIC GEAR LUBRICANT
1999 GMT 800 TRUCKS GM P/N 12378261, SAE 75W-90 SYNTHETIC AXLE LUBRICANT
ALL OTHER NON LIMITED-SLIP OR GM P/N 1052271 OR AN SAE NON LOCKING DIFFERENTIALS 80W-90 GL-5 GEAR LUBRICANT INCLUDING B AND D CARS, S/T, M/L, G, P, AND C/K TRUCKS EXCEPT GMT 800 TRUCKS, AND AS NOTED ABOVE
REAR AXLES WITH LIMITED-SLIP OR LOCKING DIFFERENTIALS
1999 GMT 800 TRUCKS GM P/N 12378261, SAE 75W-90 SYNTHETIC AXLE LUBRICANT (DO NOT ADD LIMITED SLIP ADDITIVE)
ALL OTHER LIMITED-SLIP OR USE ONLY GM P/N 1052271 LOCKING DIFFERENTIALS (DO NOT ADD LIMITED SLIP ADDITIVE) INCLUDING C/K (NON GMT 800), S/T, M/L, G TRUCKS
MEDIUM-DUTY TRUCKS (TOPKICK, KODIAK, ETC.)
VEHICLE LINE RECOMMENDED AXLE LUBRICANT MEDIUM DUTY TRUCKS GM P/N 12345841, SAE 75W-90 SYNTHETIC AXLE LUBRICANT FOR MEDIUM DUTY TRUCKS (EATON ROADRANGER AXLE LUBRICANT)
FRONT AXLES ON 4-WHEEL DRIVE VEHICLES
VEHICLE LINE RECOMMENDED AXLE LUBRICANT FRONT AXLES IN 4-WHEEL DRIVE GM P/N 1052271 OR AN SAE VEHICLES OTHER THAN GEO 80W-90 GL-5 GEAR LUBRICANT (CHEVROLET) TRACKER
FRONT AXLES IN 4-WHEEL DRIVE GM P/N 12345836, SAE 75W-90 VEHICLES IN COLD CLIMATES SYNTHETIC COLD CLIMATE FRONT WHEN EXCESSIVE SHIFT EFFORT AXLE LUBRICANT IS REQUIRED TO SHIFT INTO 4- WHEEL DRIVE
GEO (CHEVROLET) TRACKER GM P/N 12345977 OR AN SAE 80W-90 GL-5 GEAR LUBRICANT
PARTS INFORMATION:
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
FIGURES: 00 ATTACHMENTS: 00
GENERAL MOTORS BULLETINS ARE INTENDED FOR USE BY PROFESSIONAL TECHNICIANS, NOT A "DO-IT-YOURSELFER". THEY ARE WRITTEN TO INFORM THOSE TECHNICIANS OF CONDITIONS THAT MAY OCCUR ON SOME VEHICLES, OR TO PROVIDE INFORMATION THAT COULD ASSIST IN THE PROPER SERVICE OF A VEHICLE. PROPERLY TRAINED TECHNICIANS HAVE THE EQUIPMENT, TOOLS, SAFETY INSTRUCTIONS AND KNOW-HOW TO DO A JOB PROPERLY AND SAFELY. IF A CONDITION IS DESCRIBED, DO NOT ASSUME THAT THE BULLETIN APPLIES TO YOUR VEHICLE, OR THAT YOUR VEHICLE WILL HAVE THAT CONDITION. SEE A GENERAL MOTORS DEALER SERVICING YOUR BRAND OF GENERAL MOTORS VEHICLE FOR INFORMATION ON WHETHER YOUR VEHICLE MAY BENEFIT FROM THE INFORMATION.
COPYRIGHT 1998 GENERAL MOTORS CORPORATION. ALL RIGHTS RESERVED.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
PARTS INFORMATION:
So, what does all this mean. Please excuse me, but its a little confusing! Can you tell me what I need? I have a 1999 2 DR Tahoe 4X4 LT with Z71 off-road package. I am unsure of what kind of fluid goes in what and if it needs limited slip additive or not. According to my dealer (who I spoke with just today), my truck needs the limited slip additive because it did not come from the factory with synthetic. The service advisor states that only the rear diffs with regular 80w-90 gear oil (non-synthetic) needs the limited slip additive. I had it changed this past friday, so should I get it changed again asap to get the limited slip additive out of it quickly? Thanks for all your help.
Sorry,I guess it is a little confusing being that long,plus it covers quite a few vehicles.
The short of the story is you can run synthetic fluid in the front,There is a bulletin that GM came out with on the "Old-Body-Style" trucks such as yours to switch to synthetic fluid in the frt.axle in cold-climates to help the frt.diff. actuator engage quicker and easier.If you want to run GM synthetic fluid the newest part number is 89021677.
And I don't care what the dealer told you NO ADDITIVE IS NEEDED!
If you go through and read the bulletin I posted it says a couple of times "DO NOT ADD LIMITED SLIP ADDITIVE"
Print out the bulletin I posted and show it to your dealer.
I have seen here a few times where guys add it and it just made matters worse,But on the other hand I have also seen guys add it and have no problems at all.
Hopefully this clears things up,If not let me know. :mad:
Rich.
  • 4 months later...
So after reading this post, I have a question, IF the mechanic SUCKS out the fluid, since there is not a drain plug AND bolts were NOT removed, HOW was the rear differential magnet cleaned of ANY metals that has been accumilated over the years?
Sounds like to me, the cover HAS to be removed to properly do the job ....... and a new gasket put on ????? :shakehead:
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
