New Guy from Alaska
hello,
I bought my GMC Sierra 1500 last june during the employee discount. i love the truck. i had always liked GM products and after 10 years of beating around the bush/shopping, I sucked it up and bought one.
I had visions of sugarplums in my head about what i was going to do to my truck to improve it. however, money has tightened a bit since i'm getting married.
eventually, i will buy a set of rims for the truck ( i have put off buying new tires, despite my distaste for the Wrangler ST, in hopes of coupling them with new rims), but i cannot find 17" rims in the style that i want for the life of me.
i can find plenty of 17" rims in the real wide, spoke style, but i don't want to look gangster. i want to be able to drive down a fishing trail.
ideally, i would like American Racing Outlaw II rims. however, they are dicontinuing the model, and never made them in 17" to begin with. i don't want to go to a larger rim because i want to put an off road style tire on it (BFG A/T, etc), and if i went bigger it wouldn't fit under the wheel well without a lift.
do you know of other bullet-hole style rims that are availabe in 17"?
Suggestions?
Thanks.
Rockey :happysad:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
