Car Problem
RyanbabZ71
Ok 93 Ford Escort with a 1.9L. Been running great getting 28-29 mpg back and forth to work. Yesterday started it up after work and the rpms shot up and went down and the car almost stalled. Kept doing it. Finally got going and the car ran good until I hit a stop light then it would rev up and then almost die. Kinda started surging too when letting off the gas. Today when I started it (didnt drive it today) I noticed back smoke coming out the the tailpipe.
Any ideas?
:cheers:
Thanks!
How many miles are on it? I would look at the O2 sensor. Black smoke means running rich. Might be the EGR valve as well. I'm not a ford person. I can ask a guy at work who is a ford guru.
84K miles
Thanks!
My only thoughts right now are fuel pump or cat converter???
Talked to the guy at work. He said to see if there are any codes, Auto Zone and Advance Auto can read it for you for free. Then it can be a bunch of things. Engine temp sensor, if it is off it will make it run rich thinking the engine isn't up to temp, throttle position sensor. O2 sensor, EGR valve, how is the air cleaner? A clogged cat would make it loose power more than anything.
From talking to him it sounds like this is a common problem with that perticular vehicle. He has been working on an 89 doing the same thing and has changed out everything but the computer. It is still doing it but not as bad.
Sorry I couldn't help any more than that.
Thanks for the help. I talked to someone and they said it may be an 02 sensor and they have had a similar problem on a ranger pickup. We will see.
Changed plugs and 02 sensor still didnt help.
I am leaning towards the tps because at idle the car will be at appx 100 rpms then it will go up to 2000 by itself then back to 1000 then to 500 and almost die. It has died recently but starts right back up
Guest chevydeerhunter
Any ideas?
:confused:
Thanks!
Ummmm....it's a Ford? :fume:
Seriously though, maybe a vacuum leak?
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine’s vacuum fittings, hoses and accessories. It’s even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft.
A rough idle or stalling. A performance cam with lots of valve overlap can give an engine a lopping idle, but so can a vacuum leak. A really serious leak can lean the air/fuel mixture out to such an extent that an engine won’t idle at all. An EGR valve that’s stuck open at idle can have the same effect as a vacuum leak. So too can the wrong PCV valve (one that flows too much air for the application), or a loose PCV hose. The rough idle in these cases is caused by "lean misfire." The fuel mixture is too lean to ignite reliably so it often misfires and fails to ignite at all. Lean misfire will show up as elevated hydrocarbon (HC) readings in the exhaust—enough, in fact, to cause a vehicle to fail an emissions test.
Hesitation or misfiring when accelerating. This may be due to a vacuum leak, but it can also be caused by a weak or inoperative accelerator pump in a carburetor, dirty injectors, or even ignition problems such as a cracked coil, worn spark plugs or incorrectly gapped plugs.
An idle mixture that defies adjustment. When setting the idle mixture adjustment screws on a carburetor, the idle speed should start to falter as the adjustment screws are turned in to lean out the mixture. If the screws seem to have little or no effect on idle, you’ve either got a carburetor problem or a vacuum leak.
Well i replaced the throttle position sensor today it brought the RPMs back down to a constant level doesnt "search" back and forth as much like it did before between 500-2K rpms.. Finally was able to pull off the codes and 1 was for the TPS and the other was for the MAF voltage above the max. I think I will try and clean before i buy a new one.
I know its a ford but I get double the MPG of my truck so back and forth to work its nice to save some $$$.
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
