when to change plugs
yeah 100,000 miles is a long time but if GM is calling for it then I guess they have the technology to have made such a great system. I'm no mechanic but maybe the newer engines have something to do with it. I would do a visual on them at 70,000 or 80 just to see what they looked like.
Pull one out and check it..if you want to change then go for it. I did the ones on my suburban. they came out easy. Make sure the engine is completely cooled and use antisieze on the new plugs. They should be good for a lot longer than 19K though.
Modern plugs with Platinum tips don't wear like the plugs of old.
Computer controlled EFI keeps the fuel mixture at the correct ratio plus higher energy ignition systems to prevent fuel fouling OR lean fuel conditions that cause plugs to errode.
Unless you have internal engine problems (burning oil, leaking head gaskets) plugs will last a VERY long time (80 - 100 K).
Things to watch for is a drop off in fuel milage and rough idle, then I would pull the plugs and check the condition and gap of them.
Cleaning modern plugs (blasting or filing) is a NO NO! by cleaning you remove some of the Platinum and shorten the life of the plugs.
Not like the old days. I had a 68 w/ a 327 and I had to change / clean plugs and reset the dwel angle of the points every 10,000 miles. Had to replace the points every 25 - 30K . It was easy back then to check the running conditions of your engine by pulling the plugs and checking the color of the tips for lean or rich conditions. Lead gas back then made the plugs look a whole lot different than plugs to with unleaded fuels.
I'll take todays modern engines, less work and better running.
Plugs should be fine, I had mine replaced around 105k when I had a tune up done at a local chevy dealer. My plug wires are still original, I wanted them replaced but the dealer inspected them and said it really didn't need it, he said he knows lots of people with full size GM trucks that manage to get over 150k out of the plug wires before they need changing.
I always over maintain. So at 50k I'll replace mine, not that big of an expense.
The auto and spark plug manufacturers pay the engineers a bunch of money to work stuff like this out, I am sure they know what they are doing, but it just gives me a warm and fuzzy feeling when I am working on my truck..........oh heck.......I'll never see 100k anyway! LOL!!!
I rarely see under 100K - hahaha. I like to buy em cheap and well maitained. My 00 burb has 98K and ticking fast. My 98 Sierra has 137K and runs better than new. These trucks will run forever if they are taken care of. Hell I've abused a few and still had long life. My sister's F150 on the other hand....well let's not start a Ford bashing session.
Just changed mine at 50k. The looked fine and the gap was very close to where it should be on all plugs. I think one of the big reasons to at least pull them is to not have the plugs seize to the heads. So if you don't want to spend the money on new plugs, at least pull them and coat the threads with a little anti-seize.
My last 3 GM trucks I changed the plugs at 25k miles, and the gaps on all the trucks were at least .020" too wide, never ran bad, but it was much better after changing them.
I did a tune-up at 100k by the book (plugs, wires, etc.). The truck ran just the same afterwards. That tells me that all the old stuff was still working fine.
My truck is 6 years old with 88K on it. I changed the plugs at 70K (they weren't bad at all) but the truck has developed a slight vibration at idol. I'm going to go with some new taylor wires and the usual tune up stuff. 6 years or 88K is a long time for any type of plug or wire to last, but they have!
I changed mine at about exactly 100k. They still worked great and actually appeared to be in pretty good condition.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
