Fender Well Linings
i was just wondering if the 2005 silverado step side fender well lining would fit in the regular bed bed fender well linings.  its just the plastic piece like in the front i have a 2005
I don't have access to the parts for that, but you might check this thread out for a custom kit:
http://www.gm-trucks.com/forums/index.php?...ndpost&p=180185
I simply used rubberized undercoating to undercoat the painted wheet metal in the front and rear wheel wells. One problem I see with these liners is that they do not cover the upper protion of the wheel well, which is just as vulnerable to pitting from sand, gravel, and road salt.
For those who installed the liners, get some professional rquick drying undercoating and spray it on painter hweet metal areas that liners do not cover. Also, J.C. Whitney sells gallon buckets of brush on undercoating. This works very well and there is no overspray. You have to mask off portions of your fenders when using a spray can, otherwise you will get undercoating all over the truck.
