DURAMAX BURNOUTS!!!
JimsZR2
Well, Last night I cruised over to my friends house and we decided to make some movies.. :)
His dad owns a 2006 Chevy Silverado 2500HD with the 6.6 updated Duramax engine and the 6 speed Allison transmission. His current mods are AFE intake kit, Dual exhaust with 6" tips, and a Superchips power programmer.
This was all done in manual mode 2nd gear!
Video 1
Video 2
Pic 1
Pic 2
The second marks measured 300 feet :eek::D:D:bs:
I assume your friend's dad was driving or was there ?
Well, Last night I cruised over to my friends house and we decided to make some movies.. :D
Video 1
Video 2
Pic 1
Pic 2
The second marks measured 300 feet :D  :D  :bs:  :eek:
:) reminds me of happy times in my misguided youth with my friends' moms Caddy.
Yeah, My friend Tony was there also, It was his Dad that was doing the burnouts. He made a comment like, Whats it like to have a Dad thats goin on 21! hahahaha!
Guest chevydeerhunter
I like the way he left a black mark right across those nice double yellow lines. Good job.
Awesome man! I've done that before, did it in our old 00' Silverado. Silverado with the Mark III package, 5.3L and I forget what the rear end was, but that was a great truck. It smoked countless ricers off the line. :cheers: DIdnt have much up towards the top end though.
Reminds me of being in High School! We would lite that parking lot up on the last day. I had a 1991 K1500 and i dont know because i was driving but i was told that they couldnt see the whole bed of my truck becasue the smoke was so thick. Nothing like having enough power to turn posi on meaty tires :cool:
  • 2 months later...
Well, After a few programmers stacked, Exhaust, and an intake he had it on a dyno and it made 546 horse and 890 Torque at the wheels.
That was great, reminds me of the burnout with my uncles dually Chevy 454 1 ton crew cab back infront of my highschool. There was no denying that one to the principal.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
