Too hot when not moving - help!
Got a problem - On my 2000 Z71 (91k miles - 5.3L) - a/c is nice and cold and everything is fine - until I stop moving. As soon as I stop moving, the temp gauge starts to climb. Within 5 minutes or so, the thing is in the red zone and the warning message appears. It only happens when the A/c is on. If I toggle the A/C button off, the temp starts to return to normal. I've never observed any steam or other visual signs of overheating, no strange odors either.
This shouldn't happen. Any ideas on things I can check? Should be something simple, but I'm new to this stuff.
Thanks!
John
Thanks!
John
Your fan clutch may not be engaging, causing the temperature climb. A/C condenser releaser quite a bit of heat in front of the radiator. A good fan is needed to get rid of that extra heat.
Have you had the system flushed recently? Dexcool can gum-up if theres been lots of air/moisture introduced into the system. Is your compressor maybe going bad and putting an excessive load on the syatem? (just guessing here)
Great suggestions - thanks! While I was waiting for some responses, I went and had the radiator flushed just for kicks - figured it couldn't hurt. Then I went and tested it. It helped - the temp gauge still climbs, though it takes a lot longer and never reached the red area this time after 15+ minutes. So definitely an improvement with the flush. The A/c starts to blow warm when I'm sitting still, I know part of that is normal - but I might have the A/C system checked out just to be sure.
Fan clutch - hmmm - hadn't thought of that. I'll investigate - that makes a heck of a lot of sense.
Thanks a bunch guys - appreciate the knowledge. :cheers:
If the A/C is blowing warm air after you stop, then you are not getting airflow across the condenser and radiator. That sounds like your main problem. Not enough airflow from the fan.
Have it checked asap. You don't want to keep overheating that engine.
DEWFPO
ive got the same problem had the radiator flushed and refilled new thermostat dont know what it is i hate not being able to go through drive throughs in the summer haha every time the temp guage makes its first just from 210 to 225 or so i roll the windows down, put the fan on the floor and crank the heat it sucks but it beats the heck out of overheating the motor i checked my fan clutch out with somone elses suggestions and it seemed ok i have no clue when that dexcool gums up, a good flush will get it out right? thanks
I think it is indeed the fan clutch. My Chiltons has a test to perform to check the clutch, and mine failed miserably. The fan spins with very little resistance regardless of temperature. I tested it with engine "lukewarm", and then after complete warm-up. No difference in the fan's tension. No wonder the poor thing is getting too hot. The fan is not spinning near fast enough to meet airflow demand.
Picked up a fan clutch for it tonight, will swap it out after church tomorrow. I got a heavy duty one, because I tow a 25' travel trailer sometimes. I know it will be louder, but that's fine. Gotta have the cool! Like I said above, flushing the radiator did help considerably (bought me 5+ minutes at the stop light before the temp starts to creep up). But this new fan clutch should do the trick. I'll let ya know.
Thanks again -
- John
I had encountered a similar problem with my 99 Mazda 626 V6. It has two electric cooling fans: one for the radiator, and one for the A/C condenser. When the A/C is on, both fans come on and stay on. I had one of the fan motors (A/C condenser fan) fail. The A/C worked fine at higher speeds, but when I slowed down in city traffic on a hot summer day, the A/C would blow warm air and the engine coolant temperature climbed way up. Raplacing the fan motor fixed the problem for good.
This is very similar to what you are describing. If you have a fan with a clutch, a bad clutch is often the cause.
Note: Aproperly functioning fan cultch, when it engages, will make a whining noise that is quite distinctive. I had a fan clutch in my 95 Nissa pickup and it failed, but in a diferent way - it always remained engaged and made the whining noise all the time.
Update - I installed the new fan clutch today and tested it - problem solved! The truck stays nice and cool no matter how long it sits idle now. All is well.
Thanks to everyone for the suggestions!!! You saved me a bundle! :cheers:
- John
Gentlemen,
One note on fan clutches, this is a good part to buy oem. I have tried several auto parts store clutches that just plain didn't work. One thing to look for is the sensing element on the front needs to be the coil type. Do not buy any fan clutch with a flat blade type sensing element.
ken
  • 1 month later...
Hi
I must agree with Ken.
There are MANY parts you can buy for less $$ and still have quality, from other than a Dealership. Howerver "some" thiings are better left OEM.
I had a similar problem with a...ummmm not GMC veh..(Ford)
The fan clutch went out. I got a "quality" replacement from an auto parts store. That lasted about a montsh or so. I then got the "high performance, heavy duty 'you'll never need another one"' model from a well known brand "cooling experts" company. That didn't last either. I finally got OEM fan clutch. It worked flawlessly for years till I upgraded to my GMC.
does anybody believe that?
I have a hard time imagining moisture and air in anti freeze will make them turn to goo.
Yep, I've experienced it first hand (although I don't know the cause for sure but it definately gummed up). Had to have a plugged up heater core replaced in my old 2000 S10 and there was all kinds of junk floating my my coolant (truck only had 60,000 miles at the time). Since then I flush dexcool every 40k.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
