Spare tire question
Well i recently got some new wheels/tires for my HD. These are 18" rims with 33" tires. For those that have purchased bigger wheels/tires, do you upgrade your spare as well? In the almost 5 years I have owned this truck, I have not touched the spare tire once so I cant seem to bring myself to spend the money to upgrade the spare to the same wheel/tire combo i have on the rest of the truck. I've been thinking about getting rid of the spare altogether. Also, since my truck is now lifted 6", I've been thinking that the stock jack probably wouldnt work any more being that it probably doesnt raise 2 feet. What do others do in this situation? Would you keep the useless spare/jack or get rid of them?
Just make sure if you put a spare on that the outside diameter is the same, rims ans widths don't matter too much, but make sure is a 33" spare, otherwise its of no use.
When I went to 285s I switched the spare also.
As for the Jack even with the stock tires it was useless. What a joke a pop can bottle jack for a fullsize pickup. I carry a 3 ton jack in my toolbox. Handle is removable works great.
Well when i got new wheels/tires, they had different size lugs so that makes my lugwrench useless. The jack wont go high enough so thats useless too. And the spare is around 30" and my tires are 33" so that makes the spare useless as well. Looks like im just going to get rid of it all.
thanks for the suggestions.
BTW, I just found out that my insurance has 24/7 free towing so now i really have no reason to keep it all.
Jim
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
