Newbie with some ?'s on an 89 K3500
Hi all, I just bought an 89 k3500 Reg Cab 4x4 with the Silverado Package last weekend. I got it for dirt cheap and it needs some TLC. It has the 454 with the TH400 tranny. The motor is strong but the tranny isn't. Here are my questions.
A. The crankshaft damper has broken loose and is just rattling around between the block and the pulley and the engine is shaking alot. Has this happened to anyone else? what did you replace it with?
B. The TH400 that is in it won't last much longer. Has anybody ever swapped one for an upgraded 700r4 to get a 4 spd in it? Is this a bad Idea? I'm not dead set on it but I would definitely like to have a 4 spd auto instead if it's worth it.
C. Has anybody swapped the instrument cluster for the newer 91-94 cluster with the tach? does it swap easily?
Thanks
dp
Thanks
dp
The pulley should be bolted to the damper, so not sure what's going on there. The bolt that retains it into the crank snub holds the damper on...pulley can be unbolted without disturbin gthat bolt. Try torquing the bolt to the right spec and see if it stays put. Maybe the woodruff key has broke and damper starting spining on snub?
It would be easy to physically swap in a 700R4. Would need a different steering column with right amount of detents for the OD. Not sure of what would need to be done to computer to accept it though. I myself would have 400 rebuilt or swap out with a rebuilt one. They are a little cheaper then going the 700r4 route.
I would like to know myself how hard it is to swap insturment cluster....the '88-89 cluster is pretty ghetto. :smash:
  • 3 months later...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
