Yes- Another Keys/t-bar Cracking Question
I cranked my t-bars last night on my 05 z71 CC to gain 1" of extra clearance. I measured from ground to fender lip, was stock at 36", now at 37" both sides. I've read what seems like hundreds of posts about keys and t-bar cranks. My cv angles barely changed if at all from the 1" crank. My questions are:
-If I buy the ford keys (which are cheap around me 39 bucks total) what do I gain?
-With the keys installed will I back off the t-bars and yet still go higher then the 1" I've cranked?
Or will the keys alone add 1-2"? And then the tbar cranking I did total me at 3"?
-If so at 3" I'm higher then the back end and I'm sure would need longer front shocks. Am I assuming right?
-My back is stock at 38 1/4", cranked 1" like I said I'm at 37" in front so if the keys will even me up at 38 1/4 it's worth the 39 bucks plus alignment
Lastley, just opinion here, at the 1" crank my cv angles BARELY changed, it doesn't pull, and it feel the same over bumps, I.E. shocks feel fine. Do you still recommend I pay 60 bucks for an alignment? I don't want to wear out tires, but I don't see or feel the need for it.
Thanks to all.
Do you have more bolt left on your stock keys? If so, might as well crank it up more. No different that putting in Ford keys and not cranking as much. Yes, I would get it aligned if you don't want your tires wearing prematurely. Most alignments shouldn't be much more than $30 - 40 for front end only.
All the Ford keys or equivalent aftermarket keys do is allow for greater adjustment. It does nothing other than indexing the bolt more. Some trucks come from the factory with little adjustment left on the bolts. This is where the keys would be handy.
With that said...I have aftermarket keys and coil spring spacers for sale. Looking to get $100 for the set.
Ive had my mechanic do this on my old truck, but i would like to do it on my own this time.
Do i need to lift the front end up first on jacks to be able to crank the bolts? on can you just turn them while it is on the ground? also what is the recommended most amount of turns? thanx
Yes you do need to lift up the front end first. It all depends on how much cranking you have left in the bolts, I would imagine you have enough left to just level it. And make sure you get an alignment afterwards.
  • 1 month later...
I would still get an alignment. My truck rode and drove find after cranking but when you looked at from the front you could see that the tires were pitched at an angle.
Heys guys, I'm fairly new here and I would really appreciate your input. I'm a licensed tech but I have absolutely no experience with lifting trucks.
I have an 04 Sierra K1500 Crew Cab I just bought a few months ago. The truck has the factory 265/70R17 tires right now but they will soon need to be replaced and I'd like to throw some 285/70R17s in there (close to 33" I believe) as well as lift the truck up about 2, maybe 3 inches for a little better stance and a little more security when I'm gettin dirty at the farm. :banghead: I know about body lifts but I don't want to mess around with that because I'm not really gaining any clearance, the front tow hooks look dumb, I don't like the way the factory hitch hangs in mid-air, etc. I also don't want to just bring up the front, I like the factory "rake" because when I'm towing my trailer the truck sits nice and level.
I'm thinking about doing a rear add-a-leaf (and maybe a bigger block) and then cranking the torsion bars or adding these Ford keys you all talk about. Exactly what Ford are they from if I wanted to buy them? Also, I don't mind a somewhat stiffer ride (my other vehicle is a Grand Prix GXP that rides like a dump truck) but I don't want it too uncomfortable for my girlfriend. You guys mention the shocks being too short or moving out of their "sweet spot" and riding rough, would I have to change the shocks? What about a 1-2" spacer washer to move them down a little? I actually just changed the shocks (put in Rancho RS5000 factory replacements) and noticed there really isn't a whole lot of down OR upward suspension travel built into these rigs.
I would appreciate your input, guys. I'm looking to do this mostly as a "looks" thing, as I said, with the added benefit of a little more clearance. I'd also like to do it cheaply, if possible. Thanks in advance.
To the original poster , do not mistake key adjustment as a lift kit , if you can follow that idea keep the stock keys adjust a little more to get level or close to it and get an alignment.
Drunken sailor just start a new thread ..
  • 4 weeks later...
When I turned the t bars up on my truck I turned them up all the way, and got just under 3 inches on lift, I took it to the alligment shop after I got done and the checked it out, and it was all fine, that cost nothing. I have no rubbing problem on or offroad with 33 inch claws and haven't had a problem with the cv axles and I have put over 60000 miles on my truck
keys are not l a lift kit , ya you got 3 inches and lost 100% of the trucks droop ability and may even have the UCA riding on the Travel stop.. Not what any one can consider a good idea no matter how many miles you have driven it that way ..
i cranked mine and went to get it aligned and they had a very hard time trying to get it back to speck i just went up 1 inch they got the toe and camber right but cant get the caster right. I go back tommarow to let them finish but i hope its right. Anyone else have this problem? I am getting a little upset because i am thinking i just F***** up my truck.
    • After my recent rear end bumper damage, body shop has made the repairs and included a new OEM receiver hitch.  I started thinking about how it was tightened...to specs or by hand or ??.  I called the body shop and asked and they said it was tightened by an impact gun.  I said I wanted it tightened to OEM specs.  They said no problem, bring it to shop today and they will torque to specs, which they say is 74 ft/lbs.   A couple of questions,,,,   1.  Should new bolts have been used?  If so, how many are there (bill shows one and four (I assume different areas of receiver).   2.,  Since they torqued with impact gun and now are going to probably loosen and then torque to spces, will that damage/stretch the bolts?   3.  If old bolts were reused (truck has 9000 miles), is that a problem?   4.  Any other things iI may have missed with regard to receiver replacement?   Thanks!
    • Is this supposed to be in English?  "close to 100 fake, new brake pads sign on the dash board"     Pull the wheels off.  Check the brake pad thickness.  Check the sensors out.  You could have good pads and the sensors aren't in to the worn out position, but have an electrical fault with the sensor or the plug wiring to the sensor.
    • Gas or diesel???????????   You did not indicate.  Your topic just says "2022 10L80".
    • Tomorrow I go in for my third joint replacement in jus a little over a year year!  I am not worried about the surgery but I am a little annoyed about going through the recovery process again!  I keep my frustrations to myself as I do appreciate that I am truly lucky.  Knee, hip, and shoulder replacements are routine, safe and improve mobility.  The next couple of days will be slow but every day following will see steady improvement in my mobility.
    • Practical Application ISO 4406   I think this oil cleanliness thing is going to boil down to ones personal resolve. The information is there but applying it I believe will test your commitment to the machine. Implementation would involve building or buying a prefilter or purchase of an "ISOCLEAN" oil. Then installing a single digit micron bypass system. A good deal of testing and about 99.9% of you are saying at that point....yea.....not my cuppa tea. So what can you do?    You already did the first step. Get educated and leave the bias at the door. Be aware of the its, cleanliness, importance.    Do your own work if you can. Keep the equipment clean. Not just your funnel but the engine bay. Use sealed containers. Think it through.    I believe you will find, as I did, that the tightest absolute full flow filters (Beta 200) will be around 20 micron. That will yield on average a Beta 75 of 10-15 micron. They are few in number by brand and price point. Loose filters are a dime a dozen and even the best brands have lines of loose filters. Some cleverly marketed as "Extended Service". Others will market flow over efficiency. But I think the take away once informed is that the extra cost of the best offered is a bargain. There are cheaper filters with good efficiency that are equal in performance to niche brands with big prices. Your Quick Lube is about a 40 micron unit. This is where your dealer is a plus. the AC-Delco filter is a good step up from those places. Even better if you specify the UPF line.    Be skeptical of marketing. Buying an oil that is made from GTL advertised as the cleanest base oil is using a truth to support a lie. While GTL's are made from debris free gas the processing equipment and post handling is just like any other oil. It also ignores the fact that PAO's and Esters are also gas in origin. Any private prescreening testing you would do, and some have done, would yield a result only good for the batch you tested. AMSOIL and Schaeffer's have built a reputation for paying attention to this detail.    Context. Cold starts account for at least 75%, or more, of an engines wear. But of the remaining 25% ish, over 80% is caused by particle count. Now where do we find high milage motors that use this type of information efficiently? OTR trucking!      Now, anyone want to build a prefilter or off line cleaning system anyway?
