Where's Did The G80 Locking Differential Go?
I recently bought a 2005 Yukon Denali with Stabilitrak, but there is no G80 on the build sheet. I know that the G80 was an option on most GM SUVs, but I cant find it being an option on the 2005 Denali. The sales brochure mentions under the base Yukon & Yukon XL under the Stabilitrak option, "Replaces locking rear differential and 2WD traction control."
So, does anyone know, Did the G80 option become integrated with Stabilitrak, or is there no G80 option with Stabilitrak?
From what I could dig up, it looks like the Denali's did not get a G80 or even have it as an option. Instead, you get a combination of full-time all-wheel-drive, Stabilitrack, and traction control to help you out. I guess GM thinks Denali owners don't do any serious off-roading to justify the G80, or it's operation just wasn't compatible with the AWD/Stabilitrack/Traction Control trio.
Isn't that the same situation with the transfer case? They use an open diff and modulate the brakes to shift the torque around?
I was interested in getting a Sierra denali but having an AWD system like that seriously discouraged me.
I pretty sure you're right. The Denali's x-fer case is "open" and doesn't have the traditional "2-Hi, N, 4-Hi, 4-Low".
I found this quote on the following web page about Stabilitrak and G80, but it does not specific about the Denali:
"For 2005, GMC's lineup of Professional Grade full-size sport utilities delivers increased safety features, including the availability of StabiliTrak (including the G80 locking differential) and a standard enhanced passenger safety belt reminder."
http://cars.phillyburbs.com/spotlight/2005newmodels.shtml
According to this, the G80 is included with Stabilitrak, but I would think it would still list the option code (G80) on the build sheet. Oh well, hopefully the AWD will get me out if I'm stuck.
I don't believe that the G80 is offered with the Stabilitrac because the Stabilitrac is able to modulate the breaks so that power is always fed to the wheel that has the most traction. There are a lot of manufacturers out there now that are doing this rather then offering a locking or limited slip differential.
As for worrying about traction my mom has an '03 Escalade and the AWD with Stabilitrac works very good in snow and ice (can't say for mud as I have never tried it); with the system on it is very hard to loose traction, whereas when it is off the tires loose grip relatively easy.
Yeah, I'm worried about when it's off. With any of my pickups, I like to be able to drive them at the extremes in mud, snow or on ice. I would definitely be turning the stabity control off and rely on the good ol', locked 4hi or 4lo and the G80. All this nanny stuff drives me crazy. My jeep SRT8's awd system is okay for driving in the city but makes me miss having 4hi as the computer controls definitely have a lag time when moving the torque around.
The G80 rear diff was not available from the factory when you ordered the Stabilitrak system. Also from what I've read the G80 will not work with the Stabilitrak system if added after the fact. My 03 Yukon has Stabilitrak and all the regular Yukons ( not Denali ) with this system were equipped with the Borg Warner 4482 transfer case in 03. This case is fulltime 4wd and has an open differential which is locked when in 4-low. From what I can gather, the system acts like an electronic limited slip using the brakes & computer to determine which tire / tires have best traction and applies torque accordingly.
At first, in '03 and early '04, the G80 wasn't available with Stabilitrak.
However, since that point, the two have been separate options available together, and if you've seen anymore recent SUV's, for example, the Stabilitrak is standard and you can then--and most do--have the G80 locker as an additional option on certain Chevy's and standard on certain GMC's.
As for earlier Denalis, it's a bit unclear, but just open your glovebox and look on the SPID label for G80, and you'll know the answer :)
The G80 code is not on the list in my glove box, and there is nothing mentioned about the G80 in the 05 sales brochure under the Denali. Sounds like it was not even an option on the Denali cuz Stabilitrak was standard in 2005. Its just weird that I found sites on line saying the G80 comes with Stabilitrak, thats why I was wondering if it was no longer a separate production code or if the G80 is no longer an option since Stabilitrak is standard. I would call GM, but I don't expect to be able to talk to someone that can give me an answer.
Well, what you found out fits with what I said, but I do wonder about it on the Denali myself, at least in those few last years of the GMT-800's. For the past few years, Stabilitrak was standard and then the G80 was either optional or standard additionally, depending on the specific model--like, for instance, regular Yukon's had both standard and the Tahoe/Suburban had it as an option.
Right now, with the '07's, Stabilitrack AND the G80 are still equipped as such, both standard on the GMC's (Denali included) and the locker optional on the Chevy's. Good question on the '05, and also '01-04 Denali's, though...hmm.
    • It really doesn’t matter to me. Making a blanket statement that can be refuted will be. As I pointed out the information is out there. Hey google.
    • My area is one of the most affluent areas in Texas. And yet affordable housing is close by. My family business pays top wages and turnover is very low. You can’t but people in a box if you want to succeed the opportunity is there.
    • It was previously working, but the continually running compressor threw me for a loop. It wouldn't be out of the realm of possibility that a 26 year old AC system had lost some of its charge and could be exhibiting low charge indicators, so I thought I had it licked. Add some refrigerant to get the low and high pressures in range like on the old 134 systems.   I learned the continuously running compressor is normal, and that I need to know how much is in the system, as well as needing to meter what goes in. I'm only used to working on older R134a and R12 systems that aren't variable displacement. This is how we learn...LOL.   Long story short, I had a 20% off coupon for a new Jiffy Lube that opened nearby. I took it up there yesterday and they did an evac/recharge using their brand new machine from Mahle. Had a good conversation with the guy, they loved the car and I was out of there for $159 plus tax. Digitally measured charge, exactly 1.5lb of refrigerant went in.
    • In most areas of the country, wages have trailed CPI increases over time (let's say, since the 70's) and things like housing, energy, and food have vastly outpaced wages on the whole. Can't ignore that, it's very real.   That isn't to say there aren't ways to live in ways that mitigate some of that, including moving to cheaper areas of the country. In KNut's neck of the world, median housing prices in "nearby" Dallas are more like $500k. If you're raising a family and young in a successful career, your economic opportunities are probably going to be better living closer to Dallas than Cornhole. A 3 hour (6+ round trip) daily commute probably isn't tolerable for most folks. Grumpy mentioned economic migration; but we've seen what happens when people populate and grow an area. It becomes more expensive when economic opportunities come to roost.   One thing different now from back in the 70's is our quality and standard of living has changed. Healthcare is light years better, for example. But it's also much more expensive. And we have communication and information/tech tools that folks in the 70's could never imagine, and they're accessible to people of just about all incomes. Cars are light years safer, faster, and filled with tech advances. Homes are larger, more energy-efficient, and more luxurious on the whole, from starter homes to luxury homes.   Seattle was once affordable. My folks came here in the 70's with a lot of other people from California looking to escape uncontrolled sprawl, smog, and rising prices in the Bay Area. Seattle and the surrounding area has grown considerably; The home they bought for, I think it was $70k or $80k in the late 70's is now worth $1.2M today. The same house.   So while there have been obvious boosts in some areas of quality and standard of living, regarding opportunity, that's a bit more nuanced. It's really not possible for young people to get started in similar situations in areas of the country that have become "HCOL" (high cost of living). There are many more areas than before, which is to say they exclude younger workers or make their lives significantly harder. They have to commute farther and longer to afford to live in the area. They have to take outsized risk, take on more debt, significantly delay family planning. Or, they could move somewhere cheaper, but there's usually a loss of economic opportunity that comes with that. Even for the same job, it may pay a lot less in a LCOL.   What I don't like are Boomers with phones thinking they have all the answers and outright saying that if people stopped paying for their cell phone that they'd be rich. It's as stupid and misguided as people who think they'd only be rich if taxes weren't so high. Sorry guys, Elon proved you wrong on that one, I guess you're just lazy and blaming your own situation for the reason you're not wealthy. Mobile communication is basically an expectation in a modern society and workforce and it's often cheaper than having a copper landline these days, so... What's your point?
    • My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.   Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).   Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.   Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
