2003 Tahoe Door Panel Removal Help!
I have a 2003 Tahoe and I would like to remove the door panels. I was wondering if they have just the regular clips or if there are any hidden bolts. I knwo there is one bolt by the door handle. Any help would be great Thanks
Thank you. I was pulling out on it some and it seemed like it didn't want to move so I thought I woudl post a thread on it just to make sure before I broke it. Do you know of any hidden screws I should be looking for?
there is a screw near the door handle. there is a plastic cover over a screw where you open the door. pry off the plastic cover and remove the screw. on the opposite side there is a plastic push in type connector. pry it out and then remove the cover where the mirror is at. then grab the door handle and pull up. it may help to roll the window down before you pull the panel up. its really easy!!
