On The Level
I need new shocks on the truck and was thinking about leveling it out, but didn't want to sacrifce the ride. Now some say it doesn't affect the ride? Which is it? I was watching tv the other day and ready-lift? said that they level without the ride changing. So if you use a kit the ride is good? and just cranking the bars will make it a stiffer ride? Any help is good
Thanks
Chris
This is what they say-
ReadyLift™ is the fastest, safest, least expensive way to bring the front of your Chevrolet Silverado Classic level with the rear. This gives you the clearance and ability to add wheels and tires up to 33" in diameter. While other lift kits cost thousands to buy and hours to install, ReadyLift™ can be installed in about a hour by a certified mechanic, and costs less than the price of a single custom wheel. ReadyLift™ products do not affect the factory OEM ride quality or comfort. ReadyLift™ is also the only company that forges torsion keys for ultimate strength. Thats why ReadyLift™ also offers a lifetime warranty for as long as you own your vehicle against defects for all of our products.
here is the link- http://www.readylift.com/products/sfID1/6
They do the exact same thing as if you were to just buy some ford torsion keys(not sure the part number).......and will be a hell of alot cheaper.
:thumbs:
How would I find the part number for the ford to fit the chevy? And so if you just crank the bars it's a stiffer ride but with these keys it doesn't affect the ride? How much do these keys cost?
Thanks
Chris
FWIW, I used the Rancho QuickLift on mine and the ride quality didn't change at all. However, you could adjust the firmness of shocks if you so desired.
Correct me if im wrong but the readylift looks like its just new torsion keys that are indexed differently so you can get more crank out of your torsion bars.........unless im missing something.
The ford keys do the same thing.....they are indexed differently than our stock ones so you can crank the bars up a bit more.
All of these torsion bar methods of lifting come with a risk..............if you crank the front end up too much you are putting lots of strain on your cv/half shafts because you are increasing the angles........you will wear these and other front end parts out sooner.
The ford key have been discussed before on this forum and I remember someone quoting a part number.......do a search and you should be able to come up with something.
So, if the Readylift is just indexed differently than the stock keys, don't the tb's still have to be cranked? Only they can be cranked farther?
How do get by with the claim that they do NOT affect the ride?
After searching around- I keep reading that all I have to do is go to a ford dealer and ask for torsion keys from a F150 in my year, is this so? How much more strain will it put on my front end? I don't want to crank crazy, just level, will this stress my joints? And all this without suffering in the ride?
OK, I have been looking into this for my 05 Z71. From what I have found, if you raise the front with a new "key" or crank up your bar it has to be a stiffer ride. It seems logical that the only way the front will go up is to push harder with the torsion bar. Some people like the ride better, I would like mine to ride a bit stiffer. They also say that a firmer shock will be needed as the stiffer setting will make it bounce more. It has also been said that if you only go up between 1.5" - 2" it dosn't have any adverse effect on the other components. This info is not from my experience but from on line research.
Check out this guys info on the Ford keys.
http://www.fullsizechevy.com/forums/genera...acing-tech.html
On NBS 07's, how much lift is needed in the front only, to make it look level? 1.5", 2", 2.5"?
This is the look I got after I raised the front (a hair over 2").
That looks very nice which lift is that?
That's exactly the look i'm looking for. So it looks like 2" to answer my question.
I think it was 2 1/8" or 2 3/16" to be exact. I've got it written down at home, if you need.
    • After my recent rear end bumper damage, body shop has made the repairs and included a new OEM receiver hitch.  I started thinking about how it was tightened...to specs or by hand or ??.  I called the body shop and asked and they said it was tightened by an impact gun.  I said I wanted it tightened to OEM specs.  They said no problem, bring it to shop today and they will torque to specs, which they say is 74 ft/lbs.   A couple of questions,,,,   1.  Should new bolts have been used?  If so, how many are there (bill shows one and four (I assume different areas of receiver).   2.,  Since they torqued with impact gun and now are going to probably loosen and then torque to spces, will that damage/stretch the bolts?   3.  If old bolts were reused (truck has 9000 miles), is that a problem?   4.  Any other things iI may have missed with regard to receiver replacement?   NOTE:  Attached are the receiver hitch specs from my digital OEM service manual.  It shows to horizontal mounting bolts and four vertically mounted bolts.  Other sections of manual reference eight vertical bolts.   Thanks!
    • Is this supposed to be in English?  "close to 100 fake, new brake pads sign on the dash board"     Pull the wheels off.  Check the brake pad thickness.  Check the sensors out.  You could have good pads and the sensors aren't in to the worn out position, but have an electrical fault with the sensor or the plug wiring to the sensor.
    • Gas or diesel???????????   You did not indicate.  Your topic just says "2022 10L80".
    • Tomorrow I go in for my third joint replacement in jus a little over a year year!  I am not worried about the surgery but I am a little annoyed about going through the recovery process again!  I keep my frustrations to myself as I do appreciate that I am truly lucky.  Knee, hip, and shoulder replacements are routine, safe and improve mobility.  The next couple of days will be slow but every day following will see steady improvement in my mobility.
    • Practical Application ISO 4406   I think this oil cleanliness thing is going to boil down to ones personal resolve. The information is there but applying it I believe will test your commitment to the machine. Implementation would involve building or buying a prefilter or purchase of an "ISOCLEAN" oil. Then installing a single digit micron bypass system. A good deal of testing and about 99.9% of you are saying at that point....yea.....not my cuppa tea. So what can you do?    You already did the first step. Get educated and leave the bias at the door. Be aware of the its, cleanliness, importance.    Do your own work if you can. Keep the equipment clean. Not just your funnel but the engine bay. Use sealed containers. Think it through.    I believe you will find, as I did, that the tightest absolute full flow filters (Beta 200) will be around 20 micron. That will yield on average a Beta 75 of 10-15 micron. They are few in number by brand and price point. Loose filters are a dime a dozen and even the best brands have lines of loose filters. Some cleverly marketed as "Extended Service". Others will market flow over efficiency. But I think the take away once informed is that the extra cost of the best offered is a bargain. There are cheaper filters with good efficiency that are equal in performance to niche brands with big prices. Your Quick Lube is about a 40 micron unit. This is where your dealer is a plus. the AC-Delco filter is a good step up from those places. Even better if you specify the UPF line.    Be skeptical of marketing. Buying an oil that is made from GTL advertised as the cleanest base oil is using a truth to support a lie. While GTL's are made from debris free gas the processing equipment and post handling is just like any other oil. It also ignores the fact that PAO's and Esters are also gas in origin. Any private prescreening testing you would do, and some have done, would yield a result only good for the batch you tested. AMSOIL and Schaeffer's have built a reputation for paying attention to this detail.    Context. Cold starts account for at least 75%, or more, of an engines wear. But of the remaining 25% ish, over 80% is caused by particle count. Now where do we find high milage motors that use this type of information efficiently? OTR trucking!      Now, anyone want to build a prefilter or off line cleaning system anyway?
