"actual" Braking Demonstration
Guest chevydeerhunter
Anybody seen this commercial on Fox NFL today where a F*rd pickup backs out of a moving C-130 attached to a chain. The F*rd, while being towed by the airplane, applies it's massive, titanious, better-than-everyone else's brakes and stops the plane. It may be able to stop it from a slow move, but from the implied speed they show???? IIRC, the normal approach speed is 115mph and it an operating weight of approx. 83,000lbs. I sooooo call BS on that!
i seen it a dozen times already sick of it
Seems to follow the trend set by Tojo... i.e. a truck supposedly doing stuff I don't need it to do. With a Toyota you can drive up and down an over-sized teeter-totter, with a Nissan you can take the bed off and shake it upside down by a giant robotic arm and stuff won't fall out (if i'm ever upside down, not the biggest of my worries). And now with a Ford I can stop a huge plane if I ever find myself needing to do so while being chained to it.
I'll take the commercial of the Sierra trucking through the mud. Chevy's getting a little long in the tooth with the nostalgic ads (its our country, we get it). To be completely honest I kinda like the dodge commercials I've seen; a truck doing what a truck does, while the narrator tells me why its the best and what deals I can get.
-Jay
Now the Nissan Titan has the strongest frame and they proved it by having a train tug at it. That'll come in handy whenever the thing stalls on the tracks. :rolleyes:
cant wait to get as sick of that one as i am of watching the blundra commercials... saw a tundra up close and really personal this weekend, some guy a couple campsites down had a violet colored tundra :puke::crackup: he gave me the run around... i got sick to my stomach then gave him a tour of a real truck... :rolleyes:
steve :P
The Toyota commercials get me, "towing 10,000 lbs " up and down a teter totter ...hmmmm. I guess the 10 k lbs must include the truck because that little trailer don't weigh no 10,000 lbs. unless its full of gold maybe.
I told my wife when we go camping to check how many folks tow with a Gm, last camping trip she said she never noticed that before :rolleyes: . I'll stick with my GMC and know it can tow my 7K trailer and 2 K of firewood with ease :P.
One of my favorite Ford commercials is when they bragged about how big/strong the bolts securing the bed to the frame are. They then supposedly hung a truck up in the air (by the bumper or frame) to prove how strong the bolts are that hold the bed to the frame. I got lost trying to make the connection...
I also like the one where they say the super duty has more payload capacity because the leaf springs are longer. How does making the leaf spring longer (other modifications aside) have anything to do with payload capacity? Isn't payload capacity more related to spring arch? I think longer springs just serve to give a softer ride.
Gotta love marketing...
I too have noticed how many GM trucks you see pulling campers and travel trailers... good stuff!
I camp and of course pull with my Yuk XL. I make it a point to "survey" the campgrounds as we are out walking. It seems that the marjority of the trucks I see are Ford P/S 250s and 350s. Once you leave the larger campers, I see a lot of GM 1500 P ups, Burbs and Yukon XLs. But when it comes to the older folks who spend most of their time on the road towing, it seems to me it is mostly Ford P/S, then Dodge Cummins and last but not lease, GM D/As. However, I will say, I am seeing a lot more GM D/As than I used to.
This past Labor Day weekend, there were 3 or 4 Titans in the campground where we were. Of course, you have to remember, this campground is only 30 mins from the Nissan plant where they are built. The employee discount on these trucks is huge.
And with a chevy 3500 you can pull a freight train full of rail cars. :shakehead:
None of them have anything really spectacular to sell so they each highlight a insignificant point and run with it. Until a manufacturer finally comes up with something worth listening to in a 30 second sound bite other than worthless factoids drowned out by music from some washed up atrist from the 80's I'll continue to ignore them and base my purchase on experience and "real" world analysis.
Well, considering the fact that 85% of the population is as dumb as a box of Captain Crunch... it's really no wonder they flood us with such outlandish commercials. I would imagine the average idiot buys it hook line and sinker.
Thanks goodness we is all above average in here!
Yeah like the toyota ad where it catches the contaner as it falls off the cliff then pulls it back up pure BS. Then the classic where the toyota pulls the heavy trailer up the ramp then back down the other side and stops it, then the small print pops up and says " trailer equipted with trailer brakes" hell my riding lawnmower could stop it if it had trailer brakes. :shakehead:
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
