2007 Suburban Fog-lamp Bulb Replacement...
JLeosnow
I checked the owners manual and there was no information regarding fog-lamp replacement on this vehicle(2007 Suburban LT). I'm hoping someone may be able to assist me with information on the easiest way to access these bulbs for replacement. I will admit, it was wet outside when I noticed that 1 of the bulbs was burned out so there was not much motivation to lay on my back on the floor to really "size the job up" but did give it a quick look and saw no easy way to get at it for replacement. Any tips/hints/tricks on performing this would be much appreciated!
Thanks,
-John
NBS Sierra/Silverado fog light bulbs can only be purchased from dealer. May be same with yours. Very easy to change. No tools required. Just snap in/out.
EXSlider400,
So you are saying that the fog light lens/housing assy. simply pops right out from the front?
I saw no access to it from the rear.....
Thanks,
-John
you have to be able to get at it from the rear, get on ur back and you should be able to see the back of the fog lamp, just twist the bulb and it will pop out... should take no more than a minute to do
Are you just wanting to change the bulb?? That's what it sounds like. If so then just squeese the 2 prongs togeather and pull the bulob out. Isn't hard at all. Older modles just turn the bulb. Take a look at it. I promice it isn't hard.
I'm looking to figure out how to gain access to the back of the fog lamp. Once I achieve that, I'll have no problem figuring out how to R&R the actual bulb.
Thanks,
-John
thats just it, there is nothing to "achieve access to the back of the fog lamp", you can see without removing anything, you can touch it and remove the bulb with removing anything... get on ur back and look up behind it, you will see it in plain sight, nothing obstructing your view :thumbs: !!!!!!!!
