Is This Normal
I noticed my break lights go off while I am still breaking. Initally they light up normal, but if I lift just a tiny bit(although still slowing rapidly)lights go out. I dont want to get my truck smashed due to this. Is it normal/out of adjustment. I have a 2007 gmt900 with under 5000mi. Any insight would be appreciated.
Happens on all NBS trucks, unfortunately. There are other threads which talk about it here, try searching for NBS brake lights or something similar.
I am assuming the brake light switch is still adjustable on these trucks. If so, it is a very simply adjustment and the switch should be located near the middle to top of the pedal rod. If it is like older models, you simply loosen a lock nut and then screw the switch in to bring it closer to the pedal rod.
You should not have to do this on a new truck, but from what you said, the light is going off while the pedal is still depressed. I would rather have my brake lights coming on a little too soon instead of a little too late. :)
Mine are like that too. I try to adjust my braking distances accordingly, a firmer stop so the lights remain illuminated all the time. I suppose if we all start taking our trucks in reporting the problem we might see a TSB or fix sooner...
I've tried adjusting the switch on an older truck, and there is a sweet spot that any adjustment at all resulted in them not working at all correctly. Thats why I don't want to mess with adjusting it myself.
This may not be relevant to this issue, but Volkswagen had to replace thousands of faulty brake switches on their cars recently. I wonder if GM got greedy and bought their brake light switches from the same cheap source. Nothing like global economy, eh?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
