Installing Oem Splashguards...need Advice On Install
I plan on installing the GMC OEM splashguards this weekend. However, the guards did not come with any sort of film to apply to the area where the guard rubs against the lower fender flare. As the guard is rather sharp, I would rather be safe than sorry.
Anyone have suggestions on what I can use? I've looked into the 3M Protection, but it is rather expensive and I only need a small amount.
Thanks.
I bought the guards from husky and they come with the film.
How about trying to call a body shop and see if they'll sell or give you some small pieces of the film? Maybe even a body shop supply place might have smaller amounts of the film for sale.
The film that husky supplies, is it made generic or cut to size?
The film that came with the husky guards was cut to size.
Basically you just want to cover over where the guard wraps around outside of the fender lip and contacts the paint.
I had some black vinyl, used for stickers laying around and i made my own backing for the flaps. Since my truck was black I made the vinyl stick out about 1/16 to 1/8 of an inch past the flaps contour. They look good and you can't tell I did it unless you look close.
it is uneeded. even if you put the tape on there it will not make it any better when or if you will ever take them off. oh and you also dont have to put all of the screws in. 2 on the side. and if you have a air powered 90 degree drill you have to drill a hole on the bottom. that is for husky. ive put about 10-15 of them on so far. different vechiles all mount up the same way.
Thanks for ideas. I just clay bar'ed the area, applied one coat sealant, one coat carnuba, and they are on. I figured they aren't ever going to be taken off, so what the heck. And besides, finding the film was becoming a major chore.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
