8.1/allison Surges In Reverse?
My dad has a 2006 8.1l with the allison, 2wd (I think about 10,000mi). When the truck is in reverse the engine reves up and down. Sitting still, holding the break or moving. When your moving it causes the truck to surge back rythmically as the engine revs. Dealer says they have dealt with this before but never with an allison(they are lost). Does anyone know what it could be, mabey a sensor or something that controls this.
if it is very cold outside and only does it when first starting it could be hunting.
My '05 has done this since new but not very often.
DEWFPO
In certain instances when moving in reverse my dads '05 does this, it acts as if it has some sort of a tranny break on it. The engine has never done this on it's own though.
My 04 does it when its coasting to a stop in reverse. Seems to be only when its cold. I thought it was because the gear ratio is real low. Its done it since i bought it a year ago. I never really gave it much thought.
J
My 2006 8.1 does the same thing. I just thought the surging was normal for the truck. It does not do it all the time, but it would be nice to know of there is something to it, or if it is normal.
    • Fuel Update   6/7/2026   Since getting Pepper back I've been blending fuel. 50/50 E-85 - 93 pump gas. At my local pricing that is a 97 octane fuel for the price of regular and metering 48% alcohol.    This much gasoline octane locally is $10 a gallon with only one local resource!! I can blend this anywhere I find E-85.     Why? Longer range. Same no KR timing pull. More lubricious fuel. No loss in power cylinder cleanliness and a reasonable chance at seeing any future fuel dilution in the UOA's. When I blend with Shell or XOM premiums there is some friction modifier and antiwear enhancement. No cold weather starting issues either. So lots of pluses and few losses.
    • That's certainly good to hear that there was nothing alarming on the cover magnet volume wise or chunk wise of metal. I don't recall if the Banks cover holds more oil than the factor cover, what volume did you estimate that it took ?. As to the transfer case I assume you bought whatever brand you wanted of a Dexron VI automatic transmission fluid.    Have you changed the automatic trans fluid at some point and actually I don't recall if your truck is the gas or diesel version as that makes the difference as to which transmission and oil type is required in 2023. The problem with my truck is that its the gas engine with the 10 speed and I've not yet attempted to see if I can drop the pan as the silly exhaust is right in the way and I do not want to touch the exhaust system on the manifold end if I can help it, the diesel does not have the Y pipe style exhaust under the pan so is not an issue to remove the pan.
    • I have a 2014 GMC Sierra 1500 with 5.3 litre, with 400,000km. I drove it one morning and when starting later in the day it would crank but not start. I figured it had to be the fuel pump, SO i replaced the low pressure fuel pump in the tank. The problem persisted the exact same way, crank but no start. Checked a couple plugs and was getting spark. I then replaced the high pressure fuel pump under the intake. But the same problem persisted, it tried to start right after the high pressure pump replacement for a few seconds but then just cranks. I plugged in a better scan tool with live data and I can see the low pressure pump has the proper pressure but the high pressure pump is only getting 1-3mpa, when the scan tool says it should be 14mpa. The scan tool says the lower pressure fuel is in the 55-60psi range and it hold this pressure when not cranking. But the scan tool shows the high pressure fuel drop down from 2mpa to 0.   I am not sure where to go from here, any recommendations or experiences with this condition? High pressure fuel rail sensor replacement?
    • Have you had any issues with your 2.7? I’ve only heard of a few with that kind of mileage so far.    OP, I haven’t read anywhere that carbon buildup is an issue. Just make sure to use top tier fuel. They claim that it’s better than non top tier. I’m not sure about that considering my FIL has delivered fuel for years and said it’s all exactly the same.
    • It's raining on and off today, but I was able to change the rear oil and cover before it started. I ended up getting the Amsoil 75W85 for the front, 75W90 for the rear, and the right fluid for the transfer case. I wanted a cover with a drain, so that's pretty much the reason for the aftermarket one. I have a Roadmaster sway bar and had to fabricate 1" spacers for clearance, so that might be helpful if anyone has that on their truck and considering the cover swap. Old oil had 60,000 miles and just the slightest metal fuzz on the magnet; everything looked super nice. Fourth pic is just to highlight the spacers to accommodate the cover. Those bags sure make it easier than the old siphon guns.
