Hihi
roboticboredom
So i registered a few months back.. i think i only posted like 2 times.
But i am pretty new... i guess - does that still count lol :D
Recently my "drove it off the dealer lot with 2 miles on it" new 06 Sierra got the newness smashed out of it by a tow truck... :sick:
but its gettin fixed and when i get it back i'm gonna start putting some mods on it.
Didnt want to touch it before due to the fact it still had that "brand new truck" feel to it
so i am sure you all will be hearing more out of me soon. i'll try not to ask toooo many dumb questions.
but anyways
hi :)
-Beth
Welcome to the site. How did that tow truck hit yours again?
haha i have NO idea... i didnt see him till he hit me. But his motto was definatly go big or go home..
i think he wasnt going home . lol
thanks everyone :lol::tear:
