Rusty Rocker Panels?!?!?!
My 2001 1500 Silverado 4x4 has both rocker panels that are rusting through. It is not all that bad a few spots. Is it better to find a good bodyshop that will weld in new pieces or replace the whole rocker panel?
I plan on keeping this truck for a while!
Any suggestions???
I highly suggest after you get the new rockers that you find a shop that does oil undercoating.
My 1990 shows zero signs of rust. And not garaged. Zero body work. And I live in a heavy salt area.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
