Column Shifter
The 99 is giving me some grief with shifting in and out of gear, at first I thought it was the W4M but I've got the stock ECU back in and I'm still getting the problem... What happens is when I start the truck up sometimes it will indicate that its in P or else there will be nothing selected. When I put it into R or D it's a gamble wether it will really go or if it will drop into neutral, and not have any indicator lit up. However when it does go into gear (90% of the time) it is next to impossible to get it into neutral...
Do I need to replace the shifter? Is there some circuitry I can check for wear/corrosion/dirt? I'm assuming the NBS99's have electric shifting not linkage...
Thanks guys,
Jon
I'll be checking that tomorrow but something I forgot to mention which I'm thinking is relevant is that the Tow/Haul button no longer works either making me think something electronic...
I took a gander and the linkage is all good... That combined with the lack of tow/haul is making me think it's something electric... does anybody have a diagram of the shift system?
