Dealer Wants My Sierra...
I talked with my Main Boss at work today. He is the Owner of the dealership where I work at.
All of us know that new vehicle sales have been very *spotty* lately...sell 14 on a Saturday, then sell 3 Monday.
Well, turns out that he will do "whatever it takes" to sell another vehicle off his lot.
I briefly asked about a Yukon out in the front lot--it has been in inventory over a YEAR.
We still have alot of things to "iron-out", but a move like this would cost pennies...if anything at all.
Here's what I own...2008 Sierra Ext, SLE-2, 4x4, 1200 miles on it...bought new 2-9-08
Here's what I actually thought about buying back in Feb...right before I bought the pickup:
2008 GMC Yukon, Sonoma Red, Cloth, Trac control, 3.23 locker, BUT it is a 2wd truck.
Would this be a dumb move...go from a 4x4 Sierra to a 2wd Yukon?? Opinions??
I NEVER go off-road; street use only. And in the Sierra, I've never used the bed yet!
I'm afraid only YOU can answer that. :lol:
Yeah...just looking for opinions from some TRUCK guys !!
I'll sit down later on with a wholesale auction book...and I'll see how the values compare to each other in a few years.
:lol: only you can prevent forest fires.
sounds like a good idea to me, how bad are your winters?
Well, this past winter was a pain...we had alot of snow here.
But, that is a winter, according to history notes, we get once every 140 years.
I'm not worried at all about winter driving, in either 2wd or 4wd...
I would not go to a 2wd vehicle here in WI. Where are you located in WI?
are you sure it is a 3.23 rear end? If so stay away!!
Also what dealership are we talking about since I am from WI too?
What's so wrong with the 3.23 gear package??
I've driven this 08 Yukon a few times...it has plenty of acceleration for normal street use.
Forgot to mention...there is another stipulation about this whole idea...
I don't know if the Dealer can authorize anything of this nature...
I bought my Sierra under GM Employee Plan...GM likes the purchaser to own the vehicle for 6 months. Well, I've owned the truck for around 11 weeks...
Maybe the Dealer can waive this?? I don't know.
Maybe the Yukon has been on the lot so long because it's a 2WD. Probably sell more 4WD in Wisconsin. I moved Colorado from Texas and had a difficult time unloading a 2WD Tahoe - no market.
3.23 is too low. You need at least a 3.73 if not the 4.10 with the 4.8 if you want to tow anything. You will regret it if you get it down the road!!
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
