Can Anyone Run A Carfax Report
Can anyone please run a carfax report.
VIN 1GNEC13T41R225860
Thank you
Keith
Its not a CARFAX but this might help you a little,Its the warranty service history and build sheet from GM,And it has an open recall that needs done.........
GM Vehicle Inquiry System
Summary
VIN : 1GNEC13T41R225860
VEHICLE INFORMATION
Merchandising Model : CC15706 -2001 TAHOE 2WD
Warranty Start Date : 08/02/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
MAROONE CHEVROLET OF PEMBROKE PINES
PO BOX 848480
PEMBROKE PINES , FL 33084-0480
(954) 433-3300
Selling Source : 13 - CHEVROLET
Site Code : 26046
Business Associate Code : 114786
Service Contract : Yes
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 02039 REARWARD FOLDING HEAD RESTRAINTS PINCH POINT * Closed *
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION 02/02/2006 >>> Open <<<
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 08/02/2001 50 miles 08/02/2004 36050 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/02/2001 50 miles 08/02/2007 100050 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/02/2001 50 miles 08/02/2009 80050 miles
36/36000 FEDERAL EMISSION 08/02/2001 50 miles 08/02/2004 36050 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/16/2007 185687 B E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 43860 miles
08/27/2004 411416 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 35000 miles
08/25/2004 250023 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 36358 miles
08/25/2004 250023 # N0110 - BATTERY - ONE - REPLACE 36358 miles
08/25/2004 250023 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 36358 miles
06/24/2004 239272 # D1180 - SWITCH, PRESSURE CYCLING - REPLACE 35087 miles
06/24/2004 239272 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 35087 miles
06/24/2004 239272 # K9995 - CUSTOMER CONCERN NOT DUPLICATED 35087 miles
06/24/2004 239272 # Z7905 - 5-DAY COURTESY TRANSPORTATION 35087 miles
06/23/2003 148536 # F1610 - SEAL, AXLE SHAFT OIL - REAR AXLE - RIGHT - REPLACE 21450 miles
12/31/2002 105267 # V0894 - 02039 - INSTALL PROTECTIVE COVERS 17258 miles
07/15/2002 387347 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 11526 miles
07/15/2002 387347 # Z7901 - 1-DAY COURTESY TRANSPORTATION 11526 miles
07/17/2001 A25860 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
CLAIM HISTORY
Repair Order Date : 05/16/2007 Repair Order Number : 185687 Odometer Reading : 43860 miles
Serviced By : PEOPLE S CHEVROLET
580 AUTO PARK DR
CHULA VISTA, CA 91911-6026
(619) 421-3300 Selling Source : 13 - CHEVROLET
Site Code : 20407
Business Associate Code : 160970
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
06/08/2007 802 01 B E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 15233112 - HUB
Repair Order Date : 08/27/2004 Repair Order Number : 411416 Odometer Reading : 35000 miles
Serviced By : GM ROADSIDE ASSISTANCE
PO BOX 50098
PHOENIX, AZ 85076-0098
Site Code : 00690
Business Associate Code : 160087
09/03/2004 514 01 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START)
Repair Order Date : 08/25/2004 Repair Order Number : 250023 Odometer Reading : 36358 miles
Serviced By : MAROONE CHEVROLET OF PEMBROKE PINES
PO BOX 848480
PEMBROKE PINES, FL 33084-0480
(954) 433-3300 Selling Source : 13 - CHEVROLET
Site Code : 26046
09/14/2004 517 01 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 88982293 - MODULE
09/14/2004 517 02 # N0110 - BATTERY - ONE - REPLACE 19001632 - BATTERY
09/14/2004 517 03 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE
Repair Order Date : 06/24/2004 Repair Order Number : 239272 Odometer Reading : 35087 miles
PO BOX 848480
Site Code : 26046
08/24/2004 511 01 # D1180 - SWITCH, PRESSURE CYCLING - REPLACE 89040362 - SWITCH
08/13/2004 508 04 # Z7905 - 5-DAY COURTESY TRANSPORTATION
08/10/2004 507 02 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS
08/10/2004 507 03 # K9995 - CUSTOMER CONCERN NOT DUPLICATED
Repair Order Date : 06/23/2003 Repair Order Number : 148536 Odometer Reading : 21450 miles
PO BOX 848480
Site Code : 26046
07/01/2003 391 01 # F1610 - SEAL, AXLE SHAFT OIL - REAR AXLE - RIGHT - REPLACE 12471686 - SEAL-R/AX
Repair Order Date : 12/31/2002 Repair Order Number : 105267 Odometer Reading : 17258 miles
PO BOX 848480
Site Code : 26046
01/07/2003 341 01 # V0894 - 02039 - INSTALL PROTECTIVE COVERS 88880048 - COVER KIT
Repair Order Date : 07/15/2002 Repair Order Number : 387347 Odometer Reading : 11526 miles
PO BOX 848480
Site Code : 26046
07/26/2002 294 01 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 15054698 - CONTROL
07/26/2002 294 02 # Z7901 - 1-DAY COURTESY TRANSPORTATION
Repair Order Date : 07/17/2001 Repair Order Number : A25860 Odometer Reading : 0 miles
PO BOX 848480
Site Code : 26046
07/20/2001 188 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Vehicle Build
VEHICLE BUILD
Gross Vehicle Weight Rating : 3087 kg (6807 lb)
Order Number : DJBTR8
Build Date : 07/17/2001
Build Plant : 11R06
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT
AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS
ARL - PLANT CODE-ARLINGTON, TX
AS3 - CENTER AND REAR SEATS
AT5 - FOLDING CENTER SEAT
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AXP - MPV VIN IDENT POSITION
A31 - POWER WINDOWS
A95 - RECLINING BUCKET SEATS
BVE - ASSIST STEPS
B30 - WHEELHOUSING & FLOOR CARPETING
B33 - REAR COLOR KEYED FLOOR MATS
B37 - COLOR-KEYED FRONT AND REAR MATS
B85 - BRIGHT BODY SIDE MOLDINGS
C25 - REAR WINDOW WIPER & WASHER
C36 - REAR HEATER
C49 - ELECTRIC REAR WINDOW DEFOGGER
C5U - GVW RATING - 6,800 LBS
C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
C69 - AIR CONDITIONING-FRONT & REAR
DF5 - INT R/V MIRROR, LIGHT SENSITIVE W/OUTSIDE TEMP & COMPASS
DH2 - LIGHTED LH & RH VISOR MIRRORS
DK2 - ELECTRIC OSRV MIRROR W/DEFOGGER
DK7 - INTERIOR CUSTOM ROOF CONSOLE
D07 - CUSTOM FRONT FLOOR CONSOLE
EVA - EVAP EMISSION REQUIREMENT
E52 - LIFTGATE/LIFTGLASS
FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS
FK2 - TORSION BAR SPRING ADJUSTMENT
FK3 - TORSION BAR SPRING ADJUSTMENT
GT4 - REAR AXLE - 3.73 RATIO
G65 - LEVEL CONTROL MAN,SELF ADJUSTIN
G80 - LOCKING DIFFERENTIAL-REAR AXLE
JC5 - 4 WHEEL POWER DISC BRAKES
KG8 - 130 AMP GENERATOR
KNP - HD AUX TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE
NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL
NW7 - TRACTION CONTROL POWERTAIN MGMT
PF4 - CAST ALUMINUM WHEELS (REPLACES WHEELS IN PACKAGE)
QE4 - WHEEL SPARE 16 X 6.5, ALUMINUM
QMK - P265/70R16 WOL TIRES
R9F - TRACTION PACKAGE INCLUDES: *TRACTION ASSIST/RECOVERY HOOKS *LOCKING DIFFERENTIAL
R9I - TRAILER PACKAGE INCLUDES: *TRAILER HITCH PLATFORM *7-LEAD WIRE HARNESS CONNECTOR
R9J - THIRD ROW SEATING PACKAGE: *THIRD ROW SPLIT BENCH SEAT *PREMIUM SUSPENSION *REAR HEAT *P265/70 R16 TIRES
SLM - STOCK ORDERS
T96 - FRONT FOG LAMPS
UP0 - AM/FM STEREO W/CASS & CD PLAYER (REPLACES RADIO IN OPTION PKG)
UQ3 - ENHANCED AUDIO SPEAKERS
UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
VB3 - CHROME REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER
VP6 - NOISE CONTROL
VR4 - WEIGHT DISTRIB. PLATFORM HITCH
VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE PKG.
V54 - BLACK ROOF LUGGAGE CARRIER
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
V76 - RECOVERY HOOKS
XMK - TIRE FRONT P265/70R16-111S WOL
X88 - THIRD ROW FLOOR MAT DELETE
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING
YE9 - LS TRIM
YMK - TIRE REAR P265/70R16-111S WOL
ZMK - SPARE TIRE P265/70R16-111S WOL
ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID PAINT
Z82 - HEAVY DUTY TRAILERING EQUIPMENT
1SB - LS PREFERRED EQUIP GROUP INCLS: * VORTEC 5300 V8 ENGINE * AM/FM STEREO W/CD PLAYER * 9 SPEAKER SYSTEM W/SUBWOOFER * CRUISE CONTROL W/IP TELLTALE * REMOTE KEYLESS ENTRY W/ALARM * ISRV MIRROR W/COMPASS & TEMP * FRONT & REAR AIR CONDITIONING * LEATHER WRAPPED STEERING WHL * ENHANCED SUNSHADES * POWER WINDOWS * MACHINED CAST ALUMINUM WHEELS * DUAL PWR HEATED OSRV MIRRORS WITH GROUND ILLUMINATION * BODY SIDE MOLDINGS
1SZ - PREFERRED EQUIPMENT SAVINGS
12I - GRAPHITE INTERIOR TRIM
122 - GRAPHITE/MED GRAY LEATHER TRIM
6XN - COMP FRT LH COMPUTER SEL SUSP
7XN - COMPONENT FRT RH COMP. SEL SUSP
72U - 72 REDFIRE METALLIC
Delivery Information
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 08/02/2001
Delivery Type : 010 - RETAIL/INDIVIDUAL
Delivered Odometer : 50 miles
Delivering Dealer :
PO BOX 848480
(954) 433-3300
Delivery Selling Source : 13 - CHEVROLET
Delivery Site Code : 26046
Service Contract
SERVICE CONTRACT
Policy Number : 815156466
Owner Name : HUNTER
Description : 36/36000 GMPP MAJOR GUARD
Deductible Amount : $ 100
Inception Date : 11/03/2005
Expiration Date : 11/03/2008
Inception Odometer : 43889 miles
Expiration Odometer : 79889 miles
Here you go. Not the best cut and paste but it works.
2001 CHEVROLET C1500 TAHOE
1GNEC13T41R225860
4 DR. WAGON/SPORT UTILITY
5.3L V8 MPI OHV / REAR WHEEL DRIVE
Standard Equipment | Safety Options
CARFAX Xpert
Hi-I'm the CARFAX Xpert™. I'm here to help you better understand the data in this CARFAX Report. Did you know...
* We checked over 5 billion records from thousands of data sources for this vehicle
* This vehicle qualifies for the CARFAX Buyback Guarantee
* The last reported odometer reading was 43,889
Vehicle History Summary
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car.
Tab
Vehicle Ownership History Vehicle Ownership History
The number of owners is estimated by CARFAX Owner One Vehicle History Owner Two Vehicle History
Year purchased 2001 2005
Type of owner Corporate fleet lease ---
Estimated length of ownership 3 yrs. 11 mo. 2 yrs. 4 mo.
Owned in the following states/provinces Florida Tennessee
Estimated miles driven per year 10,585/yr ---
Last reported odometer reading 43,773 43,889
Vehicle Title History Vehicle Title History
CARFAX guarantees the information in this section Owner One Vehicle History Owner Two Vehicle History
Salvage | Junk | Rebuilt Guaranteed
No Problem Guaranteed
No Problem
Fire/Flood | Hail Damage | Buyback/Lemon
Guaranteed
No Problem
Not Actual Mileage | Exceeds Mechanical Limits Guaranteed
No Problem
GUARANTEED - None of these major title problems were reported by a state Department of Motor Vehicles (DMV). If you find that any of these title problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back.
Register | View Terms
Other Vehicle History Information Other Vehicle History Information
Not all accidents or other issues are reported to CARFAX Owner One Vehicle History Owner Two Vehicle History
Total Loss Check
No total loss reported to CARFAX.
No Issues Reported
No Issues Reported
Structural / Frame Damage Check
No structural / frame damage reported to CARFAX.
No Issues Reported
No Issues Reported
Airbag Deployment Check
No airbag deployment reported to CARFAX.
No Issues Reported
No Issues Reported
Odometer Rollback Check
No indication of an odometer rollback.
No Issues Indicated
No Issues Indicated
Accident Check
No accidents reported to CARFAX.
No Issues Reported
No Issues Reported
Manufacturer Recall Check
Check with an authorized Chevrolet dealer for any open recalls.
No Recalls Reported
No Recalls Reported
Basic Warranty Check
Original warranty estimated to have expired. View Info
Interested in an extended warranty?
Warranty Expired
Warranty Expired
Tell us what you know about this vehicle
CARFAX Hot Listings - Used cars for sale
Still looking? Find similar cars just listed for sale in your area.
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 5 billion vehicle history events and found 19 record(s) for this 2001 CHEVROLET C1500 TAHOE (1GNEC13T41R225860).
Purchased: 2001
Type: Corporate fleet lease
Where: Florida
Est. miles/year: 10,585/yr
Est. length owned: 8/2/01 - 7/21/05
(3 yrs. 11 mo.)
Topper
CARFAX Xpert Low mileage! This owner drove an estimated 10,585 miles per year, lower than the industry average of 15,000 miles. These vehicles can be a better value.
Date: Mileage: Source: Comments:
08/02/2001 50 Florida
Motor Vehicle Dept.
Pittsburgh, PA
Title #0083833836 Odometer reading reported
08/14/2001 Florida
Motor Vehicle Dept.
Pittsburgh, PA Registered as
corporate lease vehicle
CARFAX Xpert
Don't be confused by the two locations in this record. The title was held in Pittsburgh, Pennsylvania but the car was registered to be driven in Florida.
08/14/2001 Florida
Motor Vehicle Dept.
Pittsburgh, PA
Title #0083833836 Title issued or updated
First owner reported
Loan or lien reported
Registered as lease vehicle
05/17/2003 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
www.marooneautoplaza.com
ww.marooneautoplaza
.com Vehicle serviced
Manufacturer's recommended maintenance performed
06/27/2003 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
ww.marooneautoplaza
Maintenance inspection completed
10/23/2003 Florida
Motor Vehicle Dept.
Hollywood, FL
Title #0083833836 Registration issued or renewed
Registered as
commercial lease vehicle
Vehicle color noted as Red
11/15/2003 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
ww.marooneautoplaza
Oil and filter changed chassis lubricated
04/24/2004 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
ww.marooneautoplaza
Tire condition and pressure checked
Automatic transmission fluid flushed
Tires rotated
06/28/2004 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
ww.marooneautoplaza
Outsourced repairs completed
Engine/powertrain computer/module reprogrammed
Fuel filter replaced
A/C cycling/pressure switch replaced
08/27/2004 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
ww.marooneautoplaza
ABS/TCS computer/module replaced
Steering shaft replaced
Battery replaced
10/02/2004 Florida
Motor Vehicle Dept.
Hollywood, FL
Registered as
12/03/2004 Maroone Chevrolet of Pembroke Pines
Pembroke Pines, FL
954-433-3300
ww.marooneautoplaza
07/21/2005 43,470 Auto Auction Sold at auction
in Florida
Listed as
a fleet vehicle
CARFAX Xpert
Dealers routinely buy and sell millions of used vehicles at auction each year.
08/16/2005 43,487 Dealer Inventory
Memphis, TN Vehicle offered for sale
09/27/2005 43,773 Auto Auction Sold at auction
in Tennessee
Listed as
a dealer vehicle
10/04/2005 Dealer Inventory Vehicle offered for sale
Purchased: 2005
Where: Tennessee
Est. miles/year: ---
Est. length owned: 12/6/05 - present
(2 yrs. 4 mo.)
12/06/2005 43,889 Tennessee
Motor Vehicle Dept.
Eads, TN
Title #73559903 Title or registration issued
New owner reported
Registration updated when owner moved
the vehicle to a new location
12/06/2005 Tennessee
Motor Vehicle Dept.
Somerville, TN
Title #73559903 Registration issued or renewed
CARFAX Xpert
If you are buying this vehicle from a private seller, check to be sure any associated lien on the vehicle has been paid off.
12/07/2007 Tennessee
Motor Vehicle Dept.
Cordova, TN Registration updated when owner moved
