Another Engineering Investigation that is going on with the Trucks, much like the paint issue, this was released on May 19, 2008
gmLogoFlat.gif Service Information
2008 Chevrolet Avalanche - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 2138349 #08-07-30-024: EI08183 - 6L50, 6L80, 6L90 RWD Leak From Transmission Oil Pan or Oil Pan Gasket (Engineering Information) - (May 19, 2008)
Subject:EI08183 - 6L50, 6L80, 6L90 RWD Leak from Transmission Oil Pan or Oil Pan Gasket (Engineering Information)
<div align="left">Models:2008-2009 Cadillac CTS, Escalade, Escalade EXT, Escalade ESV, SRX, STS, XLR
2008-2009 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe
2008-2009 GMC Sierra, Yukon, Yukon Denali, Yukon XL
2008-2009 HUMMER H2
2008-2009 Pontiac G8
with 6L50, 6L80 or 6L90 Automatic Transmission (RPOs MYB, MYC or MYD)
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard the bulletin and proceed with diagnostics found in published service information. THIS IS NOT A RECALL - refer to Service Bulletin 04-00-89-053B for more details on the use of Engineering Information bulletins.
Condition
Some customers may comment on a leak from the transmission.
Correction
Important: This bulletin ONLY applies to vehicles equipped with Transmissions 6L50, 6L80 or 6L90 (RPOs MYB, MYC, or MYD). For vehicles equipped with transmissions other than these, DO NOT proceed with this bulletin - diagnose and repair according to information found in SI.
If determined through diagnosis that the leak is coming from the transmission oil pan or oil pan gasket, complete the following steps:
  1. Use the J-42220 Leak Detection Lamp and the J-28431-6 Leak Dye Kit to isolate the leak point.
  2. If a leaking transmission oil pan or oil pan gasket is found, contact either of the following engineers BEFORE any repairs are made:
Technician Name
Dealership Name and Dealership Phone Number
Complete VIN and Repair Order Number
Important: If you do not receive a call back within one hour, proceed with repairs to the transmission.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
K9519*
Transmission Oil Leak -- Engineering Information
G8
0.8 hr
CTS, SRX, STS, XLR, Corvette
1.2 hrs
Fullsize Truck/Utilities, H2
1.4 hrs
* This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
</div> © 2008 General Motors Corporation. All rights reserved.
Mike you might want to edit out the contact names and phone numbers.
That is why I am still considered a rookie, made a rookie mistake :uhoh:, thanks rich
That is why I am still considered a rookie, made a rookie mistake :lol:, thanks rich
Hey,No prob...Not that anybody here would call,or call and harass them,but you never know. :uhoh:
Thats all we need...is for someone to call and "jack them off" and then they ask..."how'd you get this number?"...and they track it back to here. :lol:
HaHa I got the number in my email. :lol:
Not that I'd bother, I have a 4 speed, plus I can't even pronounce those names.
Ha..You oughta' try talking to them!! :lol:
BTW...If we get in trouble we know who squealed :uhoh:
HaHa I got the number in my email. :uhoh:
Yeah, then we would all be out of a job...
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
