Air Dam.
Has anyone conclusively figured out what the front air dam is for on the '07/'08 GM trucks? Is it for cooling as the manual states or is it really for fuel economy? I took mine off yesterday. Don't know if I like the look or not but I'm tired of rubbing it on things my '99 Silverado never touched. Better to take it off now then to have it ripped off. I towed my 16' Alumacraft (2000lbs with trailer) yesterday in a mix of highway and in town driving and the trans temp never got above 169 and the engine temp stayed right at 210 like it always is, loaded or unloaded. If it's for cooling then I'm mixed on it's removal but if it's going to cost me 1/2 mpg I can live with that.
I took mine off after a couple weeks of owning it because I liked the look without. I do think it slightly hurt my MPG but not by much and I was willing to live with it.
I have since leveled my truck and decided that now I like the look better with it on, and it still has plenty of clearance. I do not notice a change in tranny/engine temps but keep in mind your engine has coolant for a reason and that's why it's keeping your engine temps at 210 consistently. The thermostat is probably just open more often at highway speeds when the air dam is off compared to when it is on. I wouldn't worry about that though, I would judge it more by how much you like the looks and if you are willing to lose the slightly better MPG.
The final straw was yesterday- I'm lucky enough (for once :thumbs: ) to have a 3' high by 25' long elevated vehicle stand so I can perform basic vehicle maintenance. You drive up on to it via some plate steel ramps. The approach angle is very reasonable but yet I'm scraping the air dam on the ramps. So off it came. Like I said I'm torn on the looks but WTF, I can see ripping this thing off in the winter here. I don't go 4 wheeling in the normal sense of the word but do use the 4 wheel drive for work and hunting/fishing and I can see where this air dam will not last. I had these concerns when I bought the truck BUT I did not want the horrible fuel economy of the 2500's and I could not bring myself to buy an import (I did look) and a Ford was not an option. Had an '04 and will not go that route again anytime soon.
The air dam is save you around 1MPG on the highway, the ways these turcks are design when you are running at high speed air become trapped underneath the front of the vehicle creating more drag so the air dam is suppose to channel that air down further and away from the empty cavity right behind the bumper. I took mine off due to it scrapping.
The air dam is save you around 0.01MPG on the highway, the ways these turcks are design when you are running at high speed air become trapped underneath the front of the vehicle creating more drag so the air dam is suppose to channel that air down further and away from the empty cavity right behind the bumper. I took mine off due to it scrapping.
Fixed it for ya. :thumbs:
I don't have mine on the truck and it's been near or over 100 most days lately and it's not running any hotter then normal. My gas mileage didn't change noticably when I took it off.
I've been trying to imagine what it looks like without it - do you have any pictures you can post?
Guest Riggs
wouldnt taking the air dam off actually save you MPG since it isnt hitting a almost flat piece of plastic and going under the truck instead?
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
