Piston Slap On New 5.3l
I'm considering a new Silverado, and would like to know if the piston slap issue has been properly fixed yet. If so, does anyone know what they did to cure it? Longer skirts, tighter tolerances? I heard a while back that they were putting a band-aid moly coating on the skirts. I hope that's not all they are still doing.
Piston Slap, 20 second noise on cold starts is a fact of life on many newer engines. My 130,000 mile 5.3 does it for 10 seconds on ice cold starts. So does my brother's $90,000 Mercedes. It is a function of lower friction, shorter pistons and thinner oils that do not cushion as well. After a few minutes, my engine is SILENT, genuinely SILENT.
I could not ask for a finer engineered power plant.
Ken
I agree with Ken. These engines are going 2 - 3 - 400,000 miles without internal failures with great regularity. The fact that we might not like a noise it makes on startup is not a very valid issue and obviously not a problem. (but it still annoys some)
In answer to the original Q the piston skirts were redesigned in 2002 if I remember correctly.
Ken
It does not need to be a "fact of life". It's there because of a design flaw (short piston skirts that don't belong in a truck engine) and poor manufacturing (the fact that some have it and some don't is proof of that). If you think that the knocking on cold starts doesn't accelerate wear on your skirts and cylinder walls, I have a bridge for sale.
But that wasn't what I asked. I'm wondering if the problem is still showing up on the new models, or if they have corrected it.
Ken
Yep, it's still here, better go buy a Ford. :rolleyes: Wouldn't want to own a flawed short skirt now would ya? :)
Ken
Mine is not exhibiting thr noise.
As for accelerated wear, I sold 2 of my previous trucks that had the noise, and both had 200K plus and never burned a drop of oil. The guy I sold the one to, has close to 300K on it now.
Ken
Jeff, you beat me to the "F" word. Yeah you should check out Ford, Dodge or Toyota. Maybe Toyota can use that bridge you got for sale in another commercial about their truck that's changing trucks.
Ken
So the fact these motors last hundreds of thousands of miles means nothing to you? You call that a poor design? Wow.
Ken
yeah, you should definitely sell your truck now and buy something else.
I have the piston slap momentarily on startup from the day I bought it. it now has 95K on it, uses no oil and (knock on wood) I have 0 issues other than normal maintenance.
I could not ask for a better truck and will continue to buy 1500s with 5.3 engines.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
