Nbs Driver Window Noise When Wet Or Raining Out.
when it is wet or raining out, or after a car wash, my drivers side window makes a terrible noise when opereated up or down. any clues what to look for here? was going to head to the dealer next week since it is supposed to rain here all week but did not want to hear this is normal. anyone?
It's not normal, mine is completely quiet.
  • 2 months later...
I used to have the same problem until today. I took my truck for 9000 miles service, and let know about this problem. They fixed it by replacing the rubber in the window. They told me that GM has a service bulletin for this.
I did not know there is a bulletin. I took my door panel off and lubed the moving parts, and looked at the wiring and stuff for speakers and mirrors. It solved the problem without a dealer visit. (Stressful fo "little" things)
same with my GMT 800. it 'ran out of grease'...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
