07 Nnbs 2500hd Owners Help Needed
Does anyone in here have these options on there truck, I need a 07 Silverado 2500HD with these options.
The reason I want to know is if i can use your bcm on my 1500 to help with the 6speed conversion.
i need to find someone that is willing to eather sell me there bcm or order one for me, or give me there vin number so that i can order one.
All help will be paid for.
YOUR OPTIONS AND PACKAGES
YOUR OPTIONS AND PACKAGES $0.00 Air conditioning, , single-zone manual, front climate control
$0.00 Cooling, , auxiliary external transmission oil cooler, heavy-duty air-to-oil
$0.00 Cruise control, electronic with set and resume speed, located on steering wheel
$0.00 Defogger, , rear-window, electric
$0.00 Door locks, , power
$0.00 Engine, , Vortec 6.0L Variable Valve Timing V8 SFI, (353 hp [262.8 kW] @ 5400 rpm, 373 lb-ft of torque [505.6 N-m] @ 4400 rpm)
$0.00 Floor covering, , color-keyed carpeting, with rubberized vinyl floor mats (Extended and Crew Cab models also include rear floor mats)
$0.00 GVWR, , 9200 lbs. (4173 kg)
$0.00 Glass, , Solar-Ray deep-tinted, (all windows except light-tinted glass on windshield and driver- and front passenger-side glass)
$0.00 Grille, , chrome surround
$0.00 Mirror, , inside rearview auto-dimming, with 8-point compass and outside temperature display
$0.00 Mirrors, , outside heated power-adjustable, Black, manual-folding
$0.00 Moldings, , bodyside, body-colored
$0.00 OnStar, , 1-year of Safe and Sound plan, . Includes Automatic Notification of Air Bag Deployment, Stolen Vehicle Location Assistance, Emergency Services, Roadside Assistance, Remote Door Unlock, OnStar Vehicle Diagnostics, Hands-Free Calling, AccidentAssist and Remote Horn & Lights
$0.00 Option pkg discount
$0.00 Rear axle, , 3.73 ratio
$0.00 Recovery hooks, , front, frame-mounted
$0.00 Remote vehicle starter prep package, includes Remote Keyless Entry
$0.00 Spare tire lock, keyed cylinder lock that utilizes same key as ignition and door
$0.00 Suspension Package, , Handling/Trailering, heavy-duty, includes 46 mm piston monotube shocks and 34mm front stabilizer bar
$0.00 Tires, , LT245/75R16E all-season, blackwall
$230.00 Trailering equipment, , heavy-duty, includes trailering hitch platform and 2.5-inch receiver with 2" adapter, 7-wire harness (harness includes wires for: park lamps, backup lamps, right turn, left turn, electric brake lead, battery and ground) with independent fused trailering circuits mated to a 7-way sealed connector, wiring harness for after-market trailer brake controller (located in the instrument panel harness), and single wire for center high-mounted stop lamp
$0.00 Transmission, , 6-speed automatic, heavy-duty, electronically controlled with overdrive and tow/haul mode
$0.00 Wheels, , 4 - 16" x 6.5" (40.6 cm x 16.5 cm) 8-lug chrome-styled steel, includes chrome center caps and steel spare (spare wheel will not cosmetically match the other 4 wheels) Spare not included with (ZW9) pickup box delete unless a spare tire is ordered
$199.00 XM Satellite Radio, . With a wide variety of programming, XM has something to excite any driver. Whether you want to be entertained or informed, to laugh, think, or sing, XM has the perfect channel for you - coast-to-coast, and in digital-quality sound. 3 trial months - no obligation
