Tahoe Rust Stain
Has anybody noticed a rust colored stain showing up where the weather strip comes together at the bottom on the two front door rocker plate of a 2008 tahoe with sun roof? Where does the sun roof drain?
No but that probably means your truck was transported by rail. Rail dust can be covered up to the first year or 12,000 miles (whichever comes first). Take it in and see if it can be covered.
I don't think it ever saw a rail car. It was made in Arlington Tx. and delivered to McKinnney Tx. only 50 miles away. Probably local transport.
I've seen it on my 04 Avalanche and my 08 Silverado. I think its just crappy metal in the weatherstripping.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
