Newbie From Wisconsin
Dzydvl
Good Morning everyone, :lol: it's the closest thing I could find to a wave. After a few years I decided it was time to buy American again, and with the addition of baby boy what better way to celebrate then to buy a new :cheers: .
After a few weeks of looking my wife and I finally settled on a 2008 SS Trailblazer. It was an executive driven car with a little over 3000 on the clock.
I will be honest I'm new to Trailblazers, but not to the mighty LS2 (member at ls2.com), which is the main reason we decided on the SS... I've got some questions about the car in general, but I wanted to take a second to say hi and introduce myself. If there are any major rules I should be made aware of please feel free to post up. I look forward to getting to know you all.
Take Care,
Dzy
Take Care,
Dzy
1st and most important rule:
POST PICS!!!
Welcome! Watch any good football on Sunday? :cheers:
Take Care,
Dzy
POST PICS!!!
Good Football, I wouldn't call it that... A bunch of guys running around in purple with long blonde pig tails, against some team that would have been better off playing in skirts and pom poms, not pads and helmets... :crackup:
Actually the game wasn't too bad, AP ran the ball like a stud, but against GB anyone can do that. The front line was exposed yet again, Rogers, what a joke, if you put any pressure on him, he will snap. The officiating both ways was an insult to the game. I know it washed out, but the mistakes in calls were beyond bad. I would like to see officiating crews fined for blown calls, but yet they get put back in the rotation to make mad cash watching a bunch of over-hyped athletes play a game.... :cheers: OK sorry about that, must be my bi-polar setting in again :loser:
Good Morning everyone, :cheers: it's the closest thing I could find to a wave. After a few years I decided it was time to buy American again, and with the addition of baby boy what better way to celebrate then to buy a new :cheers: .
Take Care,
Dzy
POST PICS!!!
Welcome! Watch any good football on Sunday? :D
Good Football, I wouldn't call it that... A bunch of guys running around in purple with long blonde pig tails, against some team that would have been better off playing in skirts and pom poms, not pads and helmets... :cheers:
Actually the game wasn't too bad, AP ran the ball like a stud, but against GB anyone can do that. The front line was exposed yet again, Rogers, what a joke, if you put any pressure on him, he will snap. The officiating both ways was an insult to the game. I know it washed out, but the mistakes in calls were beyond bad. I would like to see officiating crews fined for blown calls, but yet they get put back in the rotation to make mad cash watching a bunch of over-hyped athletes play a game.... :crackup: OK sorry about that, must be my bi-polar setting in again :D
Sorry I mentioned it... :lol:
:loser:
But I do agree with you 100%. And to top it off, when players that are hyped up on emotion and adrenaline get pissed at the refs for screwing up and then say something to them, THEY get fined, yet the refs get a free pass.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
