White Wheels
anyone know where i can get some 24 inch white wheels?
or do i need to get some wheels powder coated to summit white?
The only white wheels I recall seeing were steel, and no bigger than 16 or 17. There may be more out there I just do not know of any. Maybe try google and search white wheels, or 24's.
Trailer spoke wheels are painted white. However, they do not make them in ridiculous sizes such as 24 inch. May want to check some commercial truck wheels? :thumbs:
looking for something like this.not gonna lower my truck but i do like the wheels,googled all over the place, cant find anything good,or does anyone know of a good place in houston texas to shop for wheels,need someone to help with width offset tire size, and all that..
You want to put white 24" wheels on your truck and not lower it :thumbs: Sorry, but I can't just sit back and let you do that without saying Please NOOOOO!!!!
The truck in the photo looks good. I like it! But it would look horrible with those low profile tires and stock ride height.
For white wheels, I personally would pick out some I liked and have them powder coated how I want them.
Exactly what I was thinking. They'll be a bitch to keep clean though.
24s on a truck... that is sad.
If you MUST... then I'd find something I liked and have it painted. Good luck with it!
I'd go pick up one of the truck mags, like Truckin' or such, as they usually have lots of ads for different wheel dealers.
But what I would suggest is find a style of wheel you like, then have them powder coated white as the odds are low you'd find both the wheel style you like and get it in white.
I think that tirerack.com also sells aftermarket car and truck alloy wheels and tires to match as a package. Check their website as well.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
