Ok, I Will Ask - Console Question
I am like all men I guess, try to stay away from the manuals. But even the manuals have not answered my question.
What are all the odd shaped compartments for in the lid and the bottom of the center console?
I am talking about the one in the bench seat models that flips up. One compartment in the lid I am fairly sure is for credit cards, but all the others have me stumped....One is the size of a garage remote, but it will not slide in the top....
If I need to post a photo, I can, but if you know the answer, you don't need a photo anyway now do you..... :shakehead:
Oh, 2008 model sierra....
C
I put business cards in the lid, the others have me stumped too. I thought they were odd shaped too when I started trying to stick stuff in them. I've also wondered if that divider is removable too.
Can you add a pic. Just got my 2008 Silverado Z71, and maybe with the pic, we can figure it ou together.
mwmst
sealy, tx
mwmst
sealy, tx
The big one on the right is for a map, the small one on the bottom left is for buisness cards, and the one on the top left is for one of those little packages of Kleenex.
mwmst
sealy, tx
The 3 up front are for yo' 40's.
Schlitz it up!!!
:shakehead:
...one of those little packages of Kleenex.
just another example of the migration away from the 'work truck'
The long narrow slots on either side are for pens and pencils - a nice touch! Mine used to go straight to the bottom where I had trouble finding them.
"You put your weed in there"
:lol:
:lol: Too easy for the po-po to find.
I keep mine in a fake tube of K-Y jelly. No one looks in there. :pimp:
:lol:
Except the K-9. :D
:lol:
Except the K-9. :D
..Thants when you play the "it not mine" routine. Especially when you have a passenger. :D
:lol:
Except the K-9. :D
Yea, sort of the canine version of "Grrrrr.....make my day!" .....
:D
