I Is New
BuckFeverZ
Hey guys whats goin on? Some guys on here might recognize me from other forums that I am on and decided I should join here. I have a 2007 NNBS Silverado Z71 with some minor mods that include wheels and tires, Diablo Predator tune and other visual mods. Looks like a good forum with lots of info so maybe I'll learn something :sigh:
welcome... youll always learn stuff on here.. regardless if its helpful or not..
( got some nutty ones in here ) lol
You BEST not be talkin' bout me...bitch! :cheers:
:D
