2007 Nbs 4.8l For Towing
I have a 2007 NBS Chevy Silverado 4.8L WT 2WD Ext Cab Std Bed with factory tow package. Unfortunately, I have the 3.23 rear axle ratio which on the NBS puts a max tow rating at 4700 lbs. It seemed as though the 2007 Classics and older models were able to handle about 1,000 lbs more even with the 3.23 rear axle ratio. I currently pull our camper with my wife's 2007 Nissan Armada, but the lease will be up in less than a year and don't know if I will purchase another big vehicle at that time.
The camper is approximately 5500-6000 lbs loaded. I have been told by some shops that what I have will pull it fine. Online I have been reading that I really need to have a rear axle ratio of 3.73 or 4.10. With the 3.73 the tow rating is pushed to 6700 lbs. There does not seem to be anything out for 4.10 unless it is a 4WD. I have been told that the gm parts to get the job done are extremely expensive ($1,200 just for the parts).
My question to the experts .... What part #s are actually needed to complete this job? What do you recommend - tow as is? upgrade to 3.73 or 4.10? Unfortunately, trade-in values have tanked on these vehicles, so unloading it does not seem to be an option.
Thoughts
Thoughts
since you have a work truck, you would really want to go with the 4.10s. I do not consider myself an expert on the matter, but since you have the WT package, changing the rear end will definitely help. It will boost your city mileage just a little but you will pay for it on the highway (mileage loss). I would go aftermarket and have a shop do it for you if you have never built a rear end before. It will be pricey (ranging from $1500.00 to $3500.00 depending on part quality and total labor required.) I would plan on saving up $2000.00 for the complete job (that is what I was quoted to replace my 3.23s with 4.10s).
I don't think towing that heavy of a trailer with your setup will be a pleasurable experience and the truck will really have to work hard on hills. The cheapest way out is to change the gear ratio to 3.73 or 4.10. The 4.10 might be too low if you don't tow often. A 4.10 rear end can really kill fuel mileage.
Sorry must be a double post. I posted on the other one. Good luck.
Will your truck handle it? Probably fine. Will it be a pleasurable experience? I highly doubt it.
If you tow a lot, I would say get the 4.10's. If you don't tow but a couple time a year, the 3.73's should be fine. I don't know any of the part numbers you will need, but I know you can get it done MUCH cheaper than $1200 at about any other shop besides the dealer. You don't need much as far as parts...gear set, maybe a gasket(not sure if these new rear ends use gaskets or silicon) and some rear end grease.
If it were me, here is what I would do. I would pick the gears I needed (based on towing frequency), have a rear end shop install them, then I would email Justin at Blackbear performance for a tune and he will recalibrate you speedo for the new gears. I personally would probably go with 4.10s since the 4.8s like rpm.
Good luck and keep us informed.
Welcome to the site and we need pictures.
If its a once or twice a year thing, 3.73's will be fine. If its more then that, I would just go with the 4.10's. Do not buy them from the dealer or have them installed there. They will RIP you off. Since you have a 2wd, I bet you can get the new gears, master install kit, and INSTALL for about 600-1000 easy.
Yeah one set of gears should run you about 250 to 300. Parts and labor should be less than 900 bucks.
well alot of guys just say oh yeah get the 4.10s it will pull like a dream! i say otherwise. i think the gears you choose have alot to do with how often you tow and what speed you tow at. i love my 3.73s and it tows nice down the road. so my question to you is how much do you care about highway milesage when your unloaded and what speed/terrain will you tow in?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
