Transmission Fluid Dipstick - Gmt 800. Gone Missing.
Took the truck in to get the oil changed (I have to in order to keep my warranty. Can't change it myself). The technician tells me I'm missing my transmission fluid dipstick, like it's my fault. I told them I have been taking it to them for the past 4 oil changes (12,000 miles) and they were the only ones to touch underneath the hood.
Anyways, I'm trying to buy a replacement and the dealership near me tells me it will cost $45.
O'Reily's and Advance Auto Parts don't have it. I haven't got to check Autozone yet.
I have two questions:
1) what kind of damage did this do, since I've been driving around for at least 3000 miles without a dipstick
and
2) anyone know where I can go other than a dealer to pick one up?
Thanks!
2002 Silverado 1500 5.3L
and
Thanks!
I would say "F U C K you!, you sons of bitches are the only mutherfukers that have worked on it!"
the damage would be the abnormal amount of dirt and moisture that had a chance to creep in.
I agree with Mike C. and you might want to re read your warranty because if the vehicle has oil changes done and you have proof you did it they cannot void your warranty.
Thanks, but just wondering how I would have proof that I changed my own oil. I'm going to a Valvoline instant oil change place now, and I save the receipt. They also have records of me coming in on their computer.
Buy oil & filter. Keep the receipt. Keep a log. Staple receipt next to oil change date. Should work. :thumbs:
Don
Just log it into the maintenance section of your manual. That should be all you need to do.
You can do your ow oil changes and keep the receipts. As far as the dipstick I don't think it will have hurt much, and the $45 price is close what you're gonna have to pay. (take a look at ebay with shipping). It sucks though.
I always take a look at my truck and break balls if anything isn't just right after i get it worked on (which is rarely at the dealer). No greasy footprints on mat, no fluids in engine bay, etc. Unfortunately, live and learn.
ahem, sorry about my earlier post, I got pissed off about something at work and that was my line of thinking at the time. Now I am better
Yeah, I thought you could use a valium after that first post. :thumbs:
ttony,
Try a junkyard
I think I'd be changing my tranny filter and fluid.
Busy with claims today Mike?
:thumbs:
:D
F U C K yes, stupid people like the one guy that busted his damn door window out because he left his car running and didnt want to run out of gas. Dumb mutherfuker was like "yall were closed on christmas" and I was like "No Dip S H I T, we never fukking close" and he was like " I called" and I was like "who did you call" and he was like "The tow company" - DUMB MUTHERFUKER - not only did he want to have his 'roadside' claim covered, he wanted us to waive the damn deductible. I basically told that mutherfuker to fukk off. HOW FUKKING STUPID DO YOU HAVE TO BE TO BREAK YOUR OWN FUKKING GLASS AND THEN ASK TO PAY NOTHING CAUSE ITS THE FUKKING HOLIDAYS - TWO WORDS FOR YOU: FUKK OFF!!
FUKK, I would have called the local cops to come pry that b i t c h open. Fukk, now that I think about it, I have to work on the 2nd... :thumbs:
:crackup:
FUKK, I would have called the local cops to come pry that b i t c h open. Fukk, now that I think about it, I have to work on the 2nd... :D
Mike,Mike,Mike...........
You need to :thumbs::D:D
Hang in there bud,It'll get better :lol:
:D
Don't hold back, tell us what you really think :D
Don
:crackup:
See I am cool here answering questions and helping guys out to the best of my abilities (and resources)...at the end of the its all cool...I still get my check and everybodys happy (except the stupid people) :lol:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
