Auto Leveling System
mburcham
Hi, I have an 06' tb ss. I recently noticed that my auto leveling system stopped working. The pump will still work in manual with a switch at the back to pump up tires, so I know tha the pump is good. I checked the fuse. the air lines, and the sensors. all good, but the rear is sagging low, the ride is rough, and it's not pumping up automatically, any ideas????????
You will have a fault code but will need the dealer to read it or an independent shop with a Tech II scanner. This isn't something that's readable with a basic OBDII scanner. Start there and it will save a lot of time and hassle. I know from experience having just gone through diagnosiing my autoride.
Will clearing the code fix it??
Only if you fix the issue that generated the code. The code number will correspond to a specific fault and tell you which component is not functioning.
