Blond Joke
dlstewart01
This blond was telling her good friend about getting a tattoo. her friend ask her what did you get and where. She said, I got a seashell tattooed on my inner thigh. Her friend said, why did you get it put there. The blond replied, Well when you put your ear to it you can smell the ocean. :thumbs::D:D
My wife and I are watching "Who Wants To Be A Millionaire" while we are in bed. I turned to her and said, "Do you want to have sex?" "No." She answered. I then said, "Is that your final answer?" Yes." She replied. Then I said, " I'd like to phone a friend."
That's the last thing I remember.
:D:D
this blond driving down a back road and looks off to side and sees another blond off in field rowing a row boat! She is like WTF? Stops her car get out runs to the side of the road and starts yelling to the blond rowing WTf are you doing? the other blond in the boat says go eff your self! The blond on the side of the road says what? The blond in the boat is like you heard me go eff your self you stupid whore!!! Now the blond on the side of the is is getting pissed but keeps her cool and yells you know its blonds like you that give blonds like me a bad name! The blond in the boat yells back suck a D. Now the blond on the side of the road is fuming and screams IF I COULD SWIM I WOULD KICK YOUR ASS BITCH!!!!!!!! :D
As a trucker stops for a red light, a blonde catches up. She jumps out of her car, runs up to his truck, and knocks on the door.
The trucker lowers the window, and Alaska Blonde says "Hi, my name is Heather and
you are losing some of your load." The trucker ignores her and proceeds down the street.
When the truck stops for another red light, the girl catches up again. She jumps out of her car, runs up and knocks on the door.
Again, the trucker lowers the window. As if they've never spoken, the Alaska Blonde says brightly, "Hi, my name is Heather, and you are losing some of your load!"
Shaking his head, the trucker ignores her again and continues down the street. At the third red light, the same thing happens again. All
out of breath, the blonde gets out of her car, runs up, knocks on the truck door.
The trucker lowers the window. Again she says "Hi, my name is Heather, and you are losing some of your load!"
When the light turns green the trucker revs up and races to the next light. When he stops this time, he hurriedly gets out of the truck, and runs back to the blonde. He knocks on her window, and as she lowers it, he says... "Hi, my name is Kevin, it's winter in Alaska, and I'm driving a SALT TRUCK!"
Did you hear about the blonde who was shopping in Wallmart when she saw a shiny cylindrical object?
Intrigued, she asked a sale associate about it.
"Its a Thermos" he replied.
She, " What's it do?"
He, "It keeps hot things hot, and cold things cold."
Awe struck, she bought it. The next day she took it to work and set it on her desk.
The boss walked by, saw it, and asked " What's that thing?"
"Why its a Thermos, it keeps hot things hot, and cold things cold."
He, " what have you got in it?
She, " chicken soup and a couple of popsicles."
How do you confuse a blonde?
Take her to the oval office and tell her to sit in the corner.
How do you drown a blonde?
Put a scrach n' sniff sticker at the bottom of a pool!
How many blondes does it take to screw in a lightbulb?
5...
1 to hold the bulb, and 4 to spin the ladder!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
