New Winter Pics Of The Truck. Plus A Couple New Mods!
I finally bought a 06 black lower air dam and painted my tailgate handle. Not major mods at all, but made a big difference. So good time for new pics and a little fun in the movie theater parking lot :dunno:
And it's fawkin cold!
Truck looks great Kyle! I really like the black valance :dunno:
You should come down here and wash my truck for me. It hasn't been washed in over 3 weeks now :eek
Truck looks great Kyle! I really like the black valance :thumbs:
Thanks Scott. haha, no you come up here :D And there is no way i can go more than 1 week without washing one of the trucks
Black valance looks good, but your bumper pad REALLY needs to be painted... ASAP. Go. Now. Do it. Done yet?
Yeah yeah i know i know. Once taxes come back, the bumper pad and mirrors are getting painted. I have talked about it forever, but the shops around here want waaaayyy too much for color matching. Its bullshit
Looks good...but,a little too much chrome in front.Love the black look
Thanks. The grille i have had on and off like 3 times. i cant decide. It looks too plain without it, but sometimes too much with it on....?
Looks great, Kyle, except that you have something going on on your back window, a sticker of some sort, maybe. :thumbs:
Off with it!!!!! :D
Looks good, I really like your billet grille! I envy the fact that your ride is so clean. Up here (Northern Ontario) even the car wash doors are frezzing shut, not that I would get one at this temp anyway as when you do, it usually just comes out with sheets of ice and soap built up on it. Man I wish I had a floor drain in my garage so I could clean it up myself!!!
Anybody else notice the bigfoot footprints in pic #5? Haha.. just messin man. Looks good! My truck isn't near that clean and we're above freezing here!
Looks good. Would agree with the others about the front bumper.
At least the sun was shining in that 11 degree below weather!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
