Adding A Center Console 05 Silverado
Hey guys
I want to get rid of my jump seat and add a GM center console with the Bose amp/sub. I've been looking on ebay and am wondering what GM models and years will fit in my 05 Silverado Z71 Ext cab without much if any modification.
I don't like the jump seat, don't need to seat 6 and I would like a little more bass from the factory system. I'm a 30 something so I don't need to rattle the windows of the cars next to me or drown out my friends systems. I've considered the under seat options but don't want to give up the storage space under the back seat.
So, back on track, what center consoles will fit and is it safe to assume that my truck has the connectors under the dash to hook up the Bose system in the console??
Thanks!
John
I would guess 03, 04, 05, 06, 07 Classic would all work. Do you have the fold down center arm rest seat? What color interior?
Yes, that's what I was thinking as well. After looking at some more pics I am concerned that the manual 4X4 shifter will get in the way. I'm getting a little flustered with this project! Seems no one here in Indianapolis knows what I'm talking about and the first 3 GM dealers I called couldn't tell me what consoles would fit in my truck other than the $1600 one that they ALL tried to sell me! Annother issue is the wiring harness under the dash. I'm not sure if MY harness has the connectors to plug in the Bose sub/amp. Then there is the issue of will my stock GM radio accept the Bose equiptment.
IT SHOULD NOT BE THIS HARD!
I have always bought GM due to the fact that they are easy to work on, unless you are trying to add that darn console!!
Yes, I have the fold down 3rd (middle) seat in my truck, tan interior, Grey seats.
I would tend to think that if you have the manual floor shifter for the 4x4 system, you won't be able to get the console in because it pretty much takes up that space
That's what I am thinking as well. Another reason this forum is so great! A sounding board to bounce ideas around and get good feedback!! Thanks!
I have yet to find a Chevy dealer in Indianapolis I like to work with. I thought about this some at work today and with the floor shifter, it won't work. From the trucks I've seen with the console, and trucks with floor shifters(such as mine), it would be in the way. Let me know if you've found a dealer you like to work with.
I think that you need buy more than just the center console in order to get the results you desire. If I remember correctly, the passenger side bottom half of the dash needs to changed because the console actually butts up against it, I'm thinking the dash alone was more than 600 bucks from the dealer...and that was wholesale. You could look on ebay, I've seen a couple on there in the last year or so. Hope this helped
I made the exact swap on my truck last year...
It has to be a 2003-2007 Classic console, and it bolts right in....sort of.
Take out the seats and the jump seat. The console bolts to the floor right where the jump seat comes out.
Dash is an issue. Yoou need to first pull off the dash trim piece that goes around the speedometer, a/c and heat controls....pull right off.
Pull out the ashtray first, and you will see wherre the left side of the console will fit up under the lip of the dash. The glove compartment housing interfers with the right side of the console, and you have two choices.
You can either remove the glove box and surrounding trim piece that contains the ashtray brackets and replace it with the appropriate panel from GM or junk yard or doner truck, etc. I think the piece you will need costs about $300 OR A LITTLE LESS.
The other option is to smply cut out the dash to mak room for the right side of the console..
I could not find the glove box piece, so I opted to cut out the part of the dash on the right side. Originally, I thought I would cut it out and replace it later....just so I could get the console installed....a good plan I thought
However, I cut the dash in stages, taking off just a little at a time, filing it smooth and test fitting the console each time....ultimately, after about an hour or so of test fitting and shaving, it fit perfectly. My son-in-law has a GMC with the same console from the factory. There is only one tiny little spot at the top of the console that does not match his, but otherwise it looks factory original. So, I am going to leave it alone.
Sounds like a lot of messing around, but not a bad job....it does feel a bit strange when you start wacking up your dash...but you can always buy replacement parts....good luck.
Do you have any pics of the inside of your truck? I have an '04 that I am thinking of doing this exact swap. I am not trying to add any of the Bose components just the console itself so is removing the trim for the speedo and climate controls needed? I don't have anything to compare it to so I am not sure how far up the console would mate to the underside of the dash as it is now.
Nope, sorry I have no pics...camera crapped out and did not yet buy a new one....
The trim piece around the speed and a/v controls has to come off...just gently pull on the corners one at a time as it comes off easy...
The console slides up under the dash once the trim piece is removed....when the trim piece goes back on it covers the remaining little gap between the dash and the console....hope that helps.
  • 6 months later...
Guys,
I know it has been a while since this thread was active, but I've just recently purchased a Silverado with the manual shift transfer case. It came with the 40/20/40 in cloth and I just purchased the leather captions chairs and the center console. I have not found anyone that has successfully installed a center console in a truck with a floor shifter, but I am going to give it a shot. I am starting tonight and will document my steps and take pics. I will post back after I finish.
Trey :thumbs:
Guys,
Trey :thumbs:
Its gonna be a tough fit without modifying the console...here are some of my pics:
Here is a closeup of where the floor shifter would sit (before and after)
    • Thrust bearing is a very small window.  But nice try.   Turbo oil filter?  Haven't seen any failures.  Change your oil more frequently.  Use a better oil than the factory oil.
    • There is a p/n called out in the one PI that GM has.  Curt 57003 inline load adapter that is used for LED trailers that are having trouble with these newer trucks.  No cutting, no splicing, etc.  GM did update the lighting module around 2023 to better pick up trailers with LED lighting, but it still can happen.     Here's the link to the Curt site for it - 7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) SKU #57003 by CURT   The PI I am referencing - MC-10208985-9999.pdf   Its not just a GM deal either.  Newer Fords and Rams have this same problem.       In another PI, they recommend that the trailer has a Pollock brand 7 way on it as that is who makes the truck sides for the OEMs.  GM is also big on making sure the trailer is trouble free.  So no wiring issues, all lights are functional, better quality 7 way plug, etc.     The other PI I am referencing - MC-10178359-9999.pdf   The model year range is older but it is the current PI for 2014-2026.  It calls out the Pollock RV HD 7 way they recommend.
    • That's part of the problem...the EGR has already been replaced, and I've already had the complete intake assembly removed, and the EGR passages were clear at that time. That leaves wiring, PCM, or another variable that I wasn't expecting. Best I can tell, it's not wiring or the PCM, so I'm grasping for straws.   The PCM uses the MAP reading to confirm the requisite loss of vacuum in the manifold when the EGR activates. Since that's vacuum related, it involves a lot of other systems which could play a role.   The overall diagnosis has to be considered too. The fuel lines in the intake had rubbed through and were dumping fuel into the intake, drowning the cylinders in fuel, and putting raw fuel into the sump and cat converter. The fuel system has been fixed but the complete path of damage may not be. If the cat was damaged and melted the internals, it could be partially obstructed and also playing into the EGR issue.   I'm retracing my steps; trying to go back to thinking thinking Horses not Zebras based on the clues I've been given. These engines aren't *that* complex.   Could it be, now that the truck is running well, that carbon and crud from being run with the fuel system in disarray is now dislodging and clogged my clean EGR passages where I can't see?  That's what the code is actually saying. The flow is restricted, dummy. Retrace step 1.   I may just need to remove the lower intake again. Before I do that I'm going to try removing the EGR and running the engine for a few seconds to see if it will blow anything lodged in the egr passages out through the open ports.     That's been helpful in the past. For the spider injector, there's no guarantee I'll get a working one. The spider I have seems fine now that the high pressure fuel line isn't making an early delivery via large hole. SO at least I'm not marooned and looking for one of those.   Row52 (dot com) is also a good one for watching for vehicles at local yards.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
