Atv Loading Ramps
Mazer18
I'm fixin to run to the store soon to pick up a set of loading ramps for my new four-wheeler. They've got the kind there that look like a ladder with a rung, then an opening, rung, opening, so forth and they've also got an arched type that's a whole solid folding ramp with holes punched down the length and about an inch high metal lip up the sides to keep tires straight.
Which would be safer for loading/unloading in a pickup truck? Cost is negligable because I believe the solid piece is $100 and the ladder style is $110. Both are rated for approximately 750 pounds, have safety straps, and are made by the same company in the USA.
What do yall say?
I have the ladder type thats arched and folds in the middle,I use them to load/unload my John Deere,They work great for me.
Got'em at Bass-Pro Shops.......Loading Ramps
Get the solid ones with the holes punched in, they can be used for other loading things such as wheeling a hand truck up in the bed etc. There more universal.
did you use them to roll up your "pretend aftermarket wheels" into the bed of your truck when you stored them for winter?
lol sorry man :D
lol sorry man :D
Remember that "FREE" ticket I offered you for Bristol? :D
I can't figure what the advantage of the ladder types are? :D
Is it just a weight thing? Not as heavy to carry?
Don't know,I wondered the same thing :D
I just went in to see what they had,and those seemed to be the best ones for what I needed,It didn't really matter to me if they were the latter-type or the solid ones with the holes,I did want folding ones though to make them easier to haul around and store.
lol sorry man :D
Remember that pretend "FREE" ticket I offered you for Bristol? :D
Fixed. :D
lol sorry !!
Sheeeeeer ya' are :D
:D
Okay, you really do have the wheels!
Sheeeeeer I do. :rolleyes:
Really, I don't :cheers:
Fixed :idiot:
I can't figure what the advantage of the ladder types are? :rolleyes:
Yes they are lighter, the solid(one piece) design is safer, not having to worry about on ramp kick out (tethered or not) I would think more traction for an atv with muddy and wet tires...
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
