08 Crew Cab Rear Wall Has Vents Open To The Outside
Just started my sound deadening work and when I finally removed to rear wall insulation There are two trap door vents "plastic" that open to the outside. No wonder there is a lot of noise in theis area.
What are you guys doing with these vents and if I seal them what are the consquences?
They serve no purpose! GM just put them in there for the hell of it to waste money and piss off it's customers. :seeya:
:chevy:
The Nerve of those SOB's!! :D
you can still soundproof the rest of the cab and have great results, those two vents are not the only cause for cab noise.
Most of the road noise comes from the underside of the cab, not from the small space between the cab and the bed... where the vents are located
Yep the vents are there on almost all trucks. It is to help equalize the air pressure when you shut the door, running the hvac system, and just general altitude changes. Some people have had good luck sealing them up and yes you eliminate a lot of road noise doing it but you can run into issue with the hvac system not working properly. I know it sounds extremely crazy but a guy on diymobileaudio.com just finished up an install in is 2008 Ford Supercrew and he was asking the same questions about his rear cab vents. Some of the responses pointed to issues with the hvac and the in cab air pressure changes. I believe he chose to leave them alone to make sure he didn't have any issues.
Some one should tell this guy its perfectly acceptable to seal them on a Furd. He gonna have problems anyways, seal 'em. :lol:
Do this, seal them then put in a HIGH power system and watch ur windows crack.
And don't be surprised when you get a leaky windshield when the seals get popped from slamming the doors with no pressure release.
Where do you think the farts go? :lol:
:D
Exactly, that's the purpose of those vents :lol:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
