Pxamg Install Tips? 09 Silverado
Hey, I just got my PXAMG and am hoping someone else has done this and can give me some tips on the install. I don't want to tear the whole dash apart only to find out I only needed to open the glove box or something.
I've searched a bit but haven't found much on getting to the radio on this exact truck. Mine is a 2500HD LT withOUT Nav. it's the single CD player. Just not sure what pieces of trim need to be pulled off and how to do it. I have a history of breaking clips on trim pieces and I really want to avoid that on this install.
Thanks in advance, any pictures or vids would be great!
-Jer
I installed the PXAMG on my '08 without nav. You will need to pull the dash and remove the radio to get access to the wire harness that plugs into it. The dash piece that comes off is the solid piece that surrounds the radio. Grab the upper right corner (on the passenger side) and give it a tug. The piece is held in with snaps so it will come out, just be careful around the thin areas that you don't snap the dash. Also don't pull away too far because you'll have to disconnect the wire harnesses that go to the 12V DC outlets. Once it's off you'll have free access to the screws on the radio. You'll have to take the radio (and in my case also the HVAC module) off
You'll plug in there, and then the trick is locating the module somewhere. You'll see several people in here have done it, and many have write-ups with pictures. I put mine on the left side of the top glove box, between the glove box and the AC duct, and secured it with velcro. It's been there for about 3 months now and I haven't had vibrations or rattles out of it.
Best of luck!
I have done this as well, but I just velcro'd (sp?) mine to the ducting that runs directly behind the head unit. There was just enough room back in there. One word of advise is to make sure you have your RCAs connected tightly to the PXAMG. Some guys have even suggested using electrical tape to make sure they stay connected, but I haven't had a problem with them coming off yet. Its really a very easy install. If you have any questions please feel free to PM me.
Thanks, I don't think i'll be using any RCA plugs since I will only be using the ipod cable. I could see the value of putting some kind of strain relief on the ipod cable so it won't get pulled out when putting the radio back in place.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
