Changing Rear Rotors - 2001 Suburban
01Burb
I have a 2001 Suburban 4x4 1500 LT
It's time to change out the rear rotors as they are warped. I took a quick look and it looks like the rotors are part of the hub. Can someone tell me how they come off. I usually do my own brakes and am reasonably mechanically minded.
In searching for replacement rotors it seems that there are two types - one for rears w/ positraction and one for rears without. I'm not sure what I have. Is there an easy way of finding out?
Thanks.
You can determine what rear end you have by looking at the RPO codes in the glove box. I'm no help on the rotor removal.
Maybe someone else will chime in here.
In doing a parts search I only see one rotor available. The rotor has the integrated parking brake "bell" on the inside so it looks like one big unit. Once you pull the caliper off, pull the caliper bracket off and you should be able to take the rotor off. Once you pull the rotor off you'll see the drum brake parking assembly and the underlying end of the axle shaft with studs. If the rotor is rusted to the axle shaft you may need to pursuade it loose with a hammer. Be careful though as those parking brake shoes cost an arm and a leg.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
