For Sale: Alpine Type-s 10" Sub
So I'm buying stuff online for my audio system... off ebay because the prices are cheaper and blahblahblah. I couldnt find a type-s sub on ebay so i went to crutchfield. Then later that day I found a sub on ebay (same exact one I was looking for) but i had forgotten I bought it off crutchfield.. So now as the things are being shipped to my house I realized that I spent $165.99 EXTRA (129.99 + 36.00 next day air). I'm willing to sell the extra sub and ship it to anywhere in US using UPS NEXT DAY AIR for $165.99. Paypal encouraged but we can discuss other options.
Thanks.
Edit: Forgot to include link to item. http://www.crutchfield.com/p_500SWS1043/Al...pine+type+s+sub
Thanks.
Smoke a little too much that day? :cool:
haha naw my mom was home allll day that day and couldnt ahah but i prob will later today.
buy something CC
buy something CC
No thanks, I quit that a long time ago. :cool:
How much you asking for the alpine CDE-9874 stereo? And do you have the mounting cage and trim ring and everything for it? Any pics?
***NOTICE***
The Original item, the Alpine Type-S SWS-1043D 10" Sub is NO LONGER FOR SALE
Luckily, The one that I bought off of ebay, the seller was out of stock and the Crutchfield sub came today. So that clears up the double buying. And the seller refunded me fully.
And yes I can take pics and its the entire radio and Ill even include an alpine ipod adapter for cheap... since I wont need it anymore.
pics coming one second
I bought it for 149.99 from best buy plus 29.99 for the ipod cable. I'll sell them both for 95.00 plus ups ground shipping
Here are the pictures. any questions just ask.
I'm still trying to find out if that CD player is AUX input ready. I know it has one on the front, but I need one for the rear (to hook up a DVD player and a PS2 that I already have in my truck), I need a permanat aux input. IS this radio capable of controlling a CD changer? or do you know if its Ai Net or M-bus compatible? I've googled it but can't find anything.
I dont think there is one in the rear. And I don't know the answers to your other questions I'm sorry :puke:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
