cpopcorn Posted April 18, 2009 Posted April 18, 2009 First thank you in advance. I've been looking all over the net to find a place to get this information. I noticed that MS3Dale helped a couple people out so I thought I'd see if he or anyone else can help. I found online where to figure out what the option codes are for my truck, now I just need to know what they are. 1gngk26jxxj477342 I know it's a 99 Suburban, 2500, 4 x 4 with a 7.4 liter (L29) engine, the GVWR is 8000-9000, and it was built in Janesville. What else can you tell me? Thanks again !!!!!
jrrod2004 Posted April 18, 2009 Posted April 18, 2009 Most of the information should be on the SPID label in the glovebox... (Service Parts ID Sticker)
cpopcorn Posted April 18, 2009 Author Posted April 18, 2009 Most of the information should be on the SPID label in the glovebox... (Service Parts ID Sticker) I looked there but no luck. Not sure if someone removed it over the years. It has had a couple owners but is still in good shape spending it's entire life in the Portland OR area. Thanks for your information.
hotdog88gt Posted June 25, 2009 Posted June 25, 2009 Could I get a build sheet for this 2005 Suburban LS? 1GNFK16Z75J145173 Thanks...
C. Charles Hahn Posted June 25, 2009 Posted June 25, 2009 Folks, realize that you probably aren't going to get help posting VINs on here. GM contacted the owners of this forum some time back and asked that they discontinue posting build sheets and most (if not all) TSBs for copyright and other reasons. If you need information about a vehicle, the best bet is to go to a GM dealer with the VIN and see if anyone there will print you off a copy of the dealerworld/GMVIS sheet for the vehicle. You can also get a copy of the vehicle's service history (under warranty or at GM dealers) from them.
hotdog88gt Posted June 25, 2009 Posted June 25, 2009 Folks, realize that you probably aren't going to get help posting VINs on here. GM contacted the owners of this forum some time back and asked that they discontinue posting build sheets and most (if not all) TSBs for copyright and other reasons. If you need information about a vehicle, the best bet is to go to a GM dealer with the VIN and see if anyone there will print you off a copy of the dealerworld/GMVIS sheet for the vehicle. You can also get a copy of the vehicle's service history (under warranty or at GM dealers) from them. Did not know that...thanks very much. Just trying to get that info before I go in. Nothing more frustrating than asking what axle a vehicle has, or if the tow pkg is installed and getting a wishy-washy answer.
